Hi there mate,
It sounds like a nice little engine you have there.
Are you sure there are no air leaks from carb to manifold or manifold to head?
If it were a Holley you played with... I'd have suggested checking the transfer slot was adjusted correctly & ditto for the accelerator pump...
Are the twin carbs you have a factory matched pair originally from a 2tb? Could be that there is either too much or too little pump squirter shot. Could also be the transition from idle to intermediate circuit but I don't know what controls that on an asin carb. Of course with a cam & headwork the fueling requirements will have likely changed.
Is there an idle mixture screw as opposed to just an idle up screw? If so try richening or leaning noting the amount of turns so you can return to your current setting. See if either way makes a positive change & it may give a clue which direction you need to look.
Jason
