is the head gasket on upside down?
Hi all
Have a 4age big port that we have done some upgrades to and now it won't run on no3 cyl
Engine was stock and going well but in the quest for more power we put some 20V throttles on with the T3 ( or whoever it is ) manifold and car still ran fine on all cyls
Then removed head and fitted some upgraded springs and cams as well as a 0.8 steel head gasket as well as some bigger injectors
Now motor has fuel, spark and compression on all cyls but just will not fire on no3
We have changed plugs leads injectors as well as swapping them between cyls
Eg Put no 2 injector in no 3 etc and the problem still persists
In frustration we took the exhaust manifold off and ran the motor and it is spitting flames out of all ports and ran smooth
Put manifold on and problem returned so now we are all out of ideas or we have overlooked something
So anyone got any ideas as to what to try next as we are at a loss as to why this is happening
Thanks
Martin
PS. Big pos rep to Sam Q for the parts and the sexiest set of trumpets I have ever seen
Did you check valve clearances???
intakes between .006" and .010", and exhaust between .008" and .012"
Valves are set as per specs they came with
Or do you mean re check them after the rerun in period?
Didn't know you could fit the gasket on upside down. Dad fitted it so I would assume its right
When the engine is running on three cylinders, does it light up the fourth cylinder if you hold it at (say) 2500 rpm ? Or does the #3 cylinder stay dead at all engine speeds ?
Oh yeah, and it might be worth popping the original injectors back in as a test.
Cheers... jondee86
Nah stays dead at all speeds
Should have put in original post that the std injectors are back in it with no change
Does spit lovely blue and yellow flames out the ports with the exhaust manifold off
Take the exhaust manifold off again and check to see if there is anything inside it blocking off one of the ports.
Compression test it?
If it ran without the exhaust manifold but died with it on I would be looking at that first.
That aside, not ideal to slap on MLS gaskets on used block and heads....... you really need to machine both.
Okay a bit of an update on this
Did a cyl leak teats and the cyl is holding at 95% so no internal issues there
Ran motor and was still not running on that cyl
Seem to think the plug is fouling as the others look very black as well, not tuned and running rich
Going to try a set of hot plugs in it to see ifthat works and set some art of base tune if it does
If you are running this engine on the factory (MAP sensored ??) ECU, then the more you modify the engine, the more the ECU will struggle to keep it running. A fresh set of plugs is always a good things when starting a rebuilt engine... even cleaning the #3 plug and drying it out with a propane torch might be enough to get it to fire. If the exhaust back pressure is all it takes to stop it lighting up, it must be right on the edge of firing... until it gets wet down with fuel.
Cheers... jondee86
