Chemi weld is wonderful stuff, for leaks that is, for pretty much the rest of the cooling system it ain't great. In your case it seems to have done something good for the engine but from most reports and from also when I used it that stuff will be clogging up the engine until the end of time.
I had a slight head gasket leak from the water gallery to the outside of the engine in my 18RG. Used some Chemi weld and the leak went away. Did the flushes and everything as mentioned but the brown stuff was still present and is still there many years later. That said it is only a temporary fix and probably shouldn't be looked upon as a long term solution. I took the head off and replaced the gasket and fixed the problem properly but the chemi weld is still clogging up the water galleries.
Will you be doing any engine work or will you just keep driving it until it possibly happens again etc?
