Results 1 to 10 of 10
Thread: How to repair ra23/28 dash ...and others with suede
    Jun 2013
    Default How to repair ra23/28 dash ...and others with suede
    Thought i might do a thread on how to suede a dash and hide the nasty cracks , this example is on my ra23 rally car dash , also did one for one of my ra40s
    Tools required
    • suede ( from spotlight)
    • spray glue ( brought mine from super cheap)
    • A dash
    • plastic applicator
    • scissors
    cost
    spray glue = $5 to $10
    suede = cost $10 foe enough to do 2 dashes
    effort/skill = priceless
    First off
    Work out where to place the dash on your suede and fold it around.
    Work out the edges.
    Then spray glue onto the dash and the suede , let it get tacky then stick them together and smooth out , trying to avoid creases.
    Jun 2013
    Default Re: How to repair ra23/28 dash ...and others with suede
    Slowly work your way around the dash avoiding creases .
    Now the hard part !!
    Bending the suede around the curve !! takes alot of effort and patience .
    Perfect !
    Now my dash has been cut around the roll cage so the with the end i just folded it around and stapled it .
    Now you have a nice suede dash that looks good and works well !
    Well worth the effort and looks rally spec
    Jun 2013
    hope this helps someone out..
    Nov 2007
    Tasmania
    Nice job. Do you think vinyl would be harder to work with; going around curves and getting the creases out?
    Jun 2013
    hi
    no idea .. i assume it would be the same and still bend around the curves
    cheers seb
    i reckon vinyl would be harder, but nothing a gentle (very gentle) heat gun action couldnt assist with
    i reckon the biggest challenge is actually filling the cracks first before you cover. i think this is done with that space foam filler.
    Now - RA23-WRX
    Aug 2009
    brucey. vinyl is harder to use but , a trimmers trick is to use a good hair dryer or hot air gun on low heat or short bursts on high heat around curved areas whilst pulling into shape. I used to be a motor trimmer about twenty years ago and enjoyed doing restorations on classic vehicles. Unluckily i had a bad marrige and had to sell my tools to get out of debt.
    Jun 2013
    Filling in cracks is the easy part ... You can use filler foam , body filler or as I used fiberglass . Worked out fine
    Traditionalist Domestic Engineer parrot's Avatar
    I did a Datsun 1200 coupe in vinyl and it came up very well, but that didn't have any complex curves. With that, I also put a layer of 3 or 4mm foam which disguised the cracks convincingly.
    Cam mountain I feel different from the ordinary
    Nov 2007
    Tasmania
    I had a look into it and there's a vacuum technique to cover a dash with vinyl. Here's a link to a youtube clip for a Celica dash:
    http://www.youtube.com/watch?v=XLNqlKaPby8
    http://www.1stgencelica.com/viewtopic.php?f=16&t=15254
    Looks like a bit of work involved, but can turn out pretty good.
  1. Crashpad / Dash Repair - Lifting Around Vents ?
    By CLG in forum Tech and Conversions
    Last Post: 22-07-2012, 12:36 AM
  2. Dash repair/covering
    By udder in forum Tech and Conversions
    Last Post: 18-09-2008, 07:21 PM
