Shouldn't be too hard to get them custom made. There seem to be custom spring manufacturers in most states.
Dimensions of rear springs from BC are: Rear 117 mm diameter at one end, 119 mm diameter at other end (ground flat), 200mm free length, 8kg/mm.
So I guess you'd ask the spring guys for: Rear 117 mm diameter at one end, 119 mm diameter at other end (ground flat), 230mm free length, 6kg/mm. Note you will need to ask for a longer free length (as they will compress more). I'm no expert in predicting what length you will need, but given that the springs that come with the kit are only just long enough, i'd go at least 230mm, maybe even 250mm.
There might be enough of us interested to buy a few sets to lower the overall cost as well.
