Do you mean put an AE86 diff in an AE95? If so that sounds like a bad idea since you have all the pain of a diff conversion (changing mounts, changing the stud pattern on the axles) and end up with the same centre with weaker axles, plus not very big or good disc brakes.
If you want a stronger diff swap something else in. If you want disc brakes I'd look for just a brake conversion. Here in Australia ST141 Corona disc brakes bolt up to many T series drum braked diffs. They may also work on AE95s.
