Results 16 to 30 of 44
Thread: 79 Corona
    highly underrated Backyard Mechanic
    Feb 2010
    Default Re: 79 Corona
    hiro is on the money there. but it all comes down to what actually ends up on your garage floor 3sge/gte, 1j, 1g, 4age, 1uz most have been done already so the info is out there just have to dig for it.
    130 series have a few similarities to 140 series. a good person to ask is javal.
    RT104 with 4AGTE
    Some assembly required
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Its a altezza ,dont know were i got lexus from. But year its a Toyota Altezza RS200 3SGE Beams Auto Tiptronic Half Cut
    Well, the Lexus IS200 is the same as an Altezza (apart from badges/engine options etc), but either way it's not a 3SGTE
    And the auto BEAMS engines aren't as good as the manual ones (less compression, less power, milder cams, lower torque rpm peak etc)
    Nov 2008
    queensland
    Manunal it is. Just lucky i have the option of both close buy
    Nov 2008
    queensland
    So in my quest to find some info Ive found a site that some one has fitted a 3sge beams into a ke550 corrolla . ON size terms it looks very similar (are they?) even the crossmember looks to be the same.
    Mounting.. | The Southern Collective
    Feb 2010
    it'll fit.
    motor is a front sump? crossmember and swaybar has a similar setup? then it should fit.
    obviously youll need to fabricate some parts but if you want it to fit bad enough youll find a way to do it.
    RT104 with 4AGTE
    Tasmania
    130s are mid sump not front.
    Cheers Brett.
    Nov 2008
    queensland
    yes 130's are mid sumped............... but a 3sge is not
    Feb 2010
    That might pose an issue lol! You got the motor out of the xt yet? Really the centre of the xmember has to come back a few inches. Might be worth seeing if you can use a different one out of a celica or even a 140 series
    Nov 2008
    queensland
    1078542_10200240259680493_388145780_o.jpg1077884_10200240260360510_324818119_o.jpg1097645_10200240260080503_502725096_o.jpg
    i think the front somp might jussssssst miss the crossmember if anything i could space it up to clear
    http://www.thor-racing.co.uk/images/...top_beams3.jpg
    And does anyone want anything from this engine? alot of the ignition system is fairly new
    Feb 2010
    personally I would hang onto all the bits till your done just in case.
    RT104 with 4AGTE
    Nov 2008
    queensland
    the 1x aint going back in. Its stuffed
    Feb 2010
    Never should have been there to begin with freakin terrible engine
    Nov 2008
    queensland
    yes...... Ive just given up. Its got a gremlin . One minute its running sweet then the timing is gone fule mixtures are up crap then it will run fine.
    Today i even watched as the timing basicly ran away from the timing mark........... with out adjusting the dam thing
    Nov 2008
    queensland
    Small update.
    My 3sge motor i was bidding on got sniped and i missed out. But iam still putting another engine in it.It will be a holden 202 rebuilt and a celica or supra gearbox behind it.
    Reason for a 202 Its cheap and easy to work on and plenty of after market parts out there,
    Also Got the starfire out today so in my eyes thats already a improvement
  1. RT104 corona diff fit ST141 corona's?
    By cranker in forum Tech and Conversions
    Last Post: 25-11-2006, 11:07 PM
