Why not go all out and put in a Cosworth Duratec engine then?Originally Posted by deviant
the 4A-GE doesn't have the torque/power to pull the E12 series Corollas effectively (yes less torque stock then the 1ZZ and 2ZZ). I suggest you go back to the 2ZZ car and drive it again properly. They are not an engine you can get a real feel of in one drive. It took me a couple of months to get used to the feel of the engine/gear package.
I do not understand why you would have the C50 gearbox over the C60/64 though. That is just silly. You will fall out or the powerband even more so then you already do... unless you kow how to drive it properly
The gear ratios are on a fine edge and you need to be slick and precise for it to work. Using the C50 gearbox would detract from the enjoyment sooo much it's not funny. You will just end up frustrated with it.
crossmember......????? no such need for one in an aw11Originally Posted by Vios-GT_07
u sure youve done a conversion into an aw11 b4?
and there is no bar the monts are welded directly to the chassis
Mmmm Cosworth goodness. One of my friends in England has a 3 door Sierra Cosworth thats pushing around 380BHP.Originally Posted by Blue_Stivo
I would choose the SR20DET though because they are readily available here and there is an abundance of tuning parts. There is zero support (that i can find) in Australia for Cosworth engines.
How about getting the very latest Honda 2 litre V-Tec and fitting one of the off the shelf supercharger kits and ending up with 300BHP+ (like the Ariel Atom 300). Probably heading into the realms of needing very very deep pockets but its going to make the ultimate trackday weapon.
He isn't using the C50.Originally Posted by Vios-GT_07
http://www.cardomain.com/ride/2255550/2
Look at the pictures and read the text.
(my emphasis)Originally Posted by 2ZZ Engineswapper
The photos clearly show the old MR2 mounts on the new FF celica transaxle.
One thing not shown is how the shift cables are hooked up. A potential solution is mentioned, but there is no evidence of follow through. I would imagine dragging the shift cables round to the backside of the transaxle to be quite a challenge due to inadequate (?) length. The solution he proposes would avoid that, but I can't say if the MR2 select mechanism (extending through the "front" of the translaxle) would work in the 6 speed box.
photo link
Blue_Stivo nails it perfectly, the 2ZZ would be out of its element with the ratios of the 5 speed.
Have a talk to Meridian Motorsport in Melboure re cosworth enginesOriginally Posted by deviant
and 2ZZ engines too for that matter...
the Duratec is based on the Mazda 2.3L engine used in the 6 and the SP23. It's the new engine use in this years formula Atlantic series in America raplacing the 4A-GE after 20 odd years.
sorry my bad.. C50 transaxle mounts + n/a MR2 drive-shafts.. i think i'll have another look at the AW11.. must've missed something coz i still can't get the idea of how it'd fit .. the Celica has a very different engine-bay from memory.. but the link shows it's fairly simple with the only "complication" being the mount position and shift selectors.Originally Posted by 3sgte
Blue_Stivo - and yea i'd say a fair bit of skill, speed and knowledge of the package to make it work efficiently, just that one drive isn't sufficient to learn it and one drive alone doesn't do it justice. It did put me off because of its first impression but given a chance i'd definitely take it up!
Looking at the custom work involved for the AW11, a 2ZZ swap into ZZW30 model seems more appealing. 960kg kerb weight in street trim and huge availibility of new parts (hard tops ftw).
Stroke the engine out to 1.93 litres, head and cam work, a Motec computer running the standard 6 speed sequential gearbox. C-One close ratio gear set. Maybe swap the stock LSD for something more agressive. Alternately, source a manual import model and go with a PowerFC to save some cash.
Build a Lotus-eating Japanese monster =)
Absolutely, I love the new MR2. But we got saddled with a *dammit* auto-only (ok, so it's got a wank 'sequential' shifter, but we all know how much that's worth), even the yanks got the manual. 2ZZ would be awesome...now I'm thinking all over again...
RM.
several of those have been built very sucessfully in the US. There is currently one in constustion in Sydney that will look awesome when complete. They have resprayed the entire chassis Cobolt Blue as well as detailed engine components to match. Will be an awesome showcar when completeOriginally Posted by buck naked
Tell me about it! It put a big dent in my apprecaition of the MRS (not my wife!). Still maybe on the bright side, I bet there's several kg of solenoids in the rear that would save weight if removed (i.e convert to a proper manual). I read that Toyota used the 1ZZ in the MR2 because it resulted in a car with better drivability, i.e. torquier at lower revs. But I have to admit a 2ZZ would seem like a logical idea for a factory hot-up MR2.Absolutely, I love the new MR2. But we got saddled with a *dammit* auto-only (ok, so it's got a wank 'sequential' shifter, but we all know how much that's worth), even the yanks got the manual. 2ZZ would be awesome...now I'm thinking all over again...
On one of the BMI (Best Motoring International) DVDs that I *ahem* previewed on the internet "NA battles at 10,000rpm" they race a 2ZZ MRS. Unfortunately it came last, but still it was cool.
Nick.
== 4AGZE SC14 Supercharged ==
