do you have/can you borrow an infrared temp measuring thing?
could start and idle (or run pumps with engine off), then go around fuel system and see what gets hottest fastest, keeping in mind that the fuel will be carryign the heat effectively, but hopefully one part is hotter than the rest (ie, rails, or reg, or there is temp differential between inlet and outlet of fuel pump)
with a bit of luck, you might be able to find the heat source
hands are pretty sensitive...
