Results 1 to 8 of 8
Thread: Cleaning up valves - removing carbon build up
    Mar 2011
    Default Cleaning up valves - removing carbon build up
    Hi all,
    I have a set of 4age 20v valves that need a clean up before I put them back into the head. Is there a quick and easy way of removing the carbon build up off the face of the valve, and also the back of the face where the stem starts?
    I have read anything from oven cleaner to gasket remover will work, others say wire brush and time...
    So who has first hand experience in cleaning valves? Should I just grit blast them?
    Dave.
    SHEPPO..
    Default Re: Cleaning up valves - removing carbon build up
    ive used oven cleaner and some scotch brite. worked well. There are little scotch bite pads you can buy that attach to a drill. those are sweet for cleaning things like valves, pistons etc
    perth
    wire buff.
    Junior Member Grease Monkey ta22fan's Avatar
    May 2008
    A nylon brush drill attachment works well on the valve faces. Gasket remover (which is basically concentrated paint stripper) is good for cleaning up light carbon on the stems.
    Chiba
    I use oven cleaner on steel/iron parts (DO NOT use it on brass/copper/alloy etc parts!!)
    For valves, I just give them a good scrub on a wire wheel with brass bristles on the bench grinder.
    oregon
    I use a wire wheel
    Tasmania
    Wire wheel is your best friend.
    Mar 2011
    Wire wheel it is! Thanks guys.
    SHEPPO..
  1. Removing carbon from combustion chamber.
    By Mickey H in forum Tech and Conversions
    Last Post: 29-05-2010, 03:48 PM
  2. Replies: 9
    Last Post: 12-04-2008, 05:59 PM
  3. Cleaning exhaust manifold of carbon buildup
    By tiang in forum Tech and Conversions
    Last Post: 14-08-2007, 03:31 PM
  4. Legalities of Removing & Refitting Build Plates
    Last Post: 18-10-2006, 12:49 PM
  5. Re: Cleaning ISC valves
    By ajh in forum Tech and Conversions
    Last Post: 17-09-2006, 08:09 PM
