Results 1 to 15 of 16
Thread: Cleaning exhaust manifold of carbon buildup
    Default Cleaning exhaust manifold of carbon buildup
    What should i use? Petrol, turps, screwdriver, fingers?
    2ZZGE MRS
    Default Re: Cleaning exhaust manifold of carbon buildup
    Take it to a paint shop and let them whip blast it.
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Oxy torch FTW
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    I would think a sand blaster would be pretty good, but I have to ask why would you care?
    the 2 middle cylinders are gone, and all the gunk has gone into the header piping. I've scrapped away most of the gunk, but it'ld be nice to get rid of it all.
    2ZZGE MRS
    what about just a high pressure wash nozzle in there? would it stand a chance?
    bunnings sell cheap high-pressure water sprayers.
    remove part from engine, spray away, clean up black watery stains left all over garage....
    why not take the exhaust manifold off, and bring it to the car-wash, for 2 bucks you get 5 minutes or something?
    ... cause you can write your name in the dirt-encrusted floor of the garage/carport/... area with the fine nozzle on the sprayer?
    Quote Originally Posted by Vios-GT_07
    FTMFW!!
    Malicious
    try spraying WD40/RP7 or whatever in there and let soak for a day or two... and then try to scrape off?
    alternatively, if you put it in an oven at around 800C, in air or oxygen rich, it will decarburise
    Easy off oven cleaner.($3-4.00 can), let it soak for an hour then hit it with the high pressure wash.
    oregon
    Tried a machine shop???? They are always tanking parts to clean then...... just a brainfart
    I use between 150 - 180PSi of air (From a large compressor)
    Works wonders, just becareful, shit flys everywhere, and don't hit your skin. Air bubbles under the skin can kill.
    Western Aus
    acid dip ftw?
    Elmo.
  1. 4AGTE - Exhaust manifold warping
    By tan18d in forum Tech and Conversions
    Last Post: 05-05-2009, 05:36 PM
  2. 18RG/EU Exhaust Manifold / Flange Plates
    By Spectre in forum Tech and Conversions
    Last Post: 25-11-2006, 12:28 PM
  3. Help... 1j exhaust manifold
    By iSOARu in forum Tech and Conversions
    Last Post: 09-02-2006, 05:41 PM
