Results 1 to 8 of 8
Thread: Unhealthy wiper motor - replace/rebuild/other?
    Mar 2011
    Default Unhealthy wiper motor - replace/rebuild/other?
    Hi guys,
    I am in the process of a full rebuild on my TA22 Celica and I've discovered the wiper motor isn't too healthy (sounds like a coffee grinder, and the wiring inside has all perished causing shorts).
    So I'm wondering what my options are regarding replacing/rebuilding it?
    Options:
    • Replace with a 2nd hand unit and hope it will last
    • Replace with an aftermarket / reco item - do they exist? if so where would I get one?
    • Rebuild the one I have - can someone recommend a place that can fix it?
    Any help would be appreciated.
    Dave
    SHEPPO..
    Jun 2010
    New South Wales
    Default Re: Unhealthy wiper motor - replace/rebuild/other?
    Dave
    Re the second dot point, you could check out the Ratsport UK website. They sell the 'rack & pinion' type wiper systems.
    Pete
    Jun 2010
    New South Wales
    Quote Originally Posted by Nevakikamukau View Post
    Dave
    Pete
    Oops,
    Make that the Europa Spares website.
    Pete
    Tallahassee, FL USofA
    Take it apart, clean up the commutator, clean or replace the brushes, clean & grease the bearings & gears.
    Make sure all the linkage & shafts move freely.
    I'd love me some Backyard Mechanic king-szeitszam's Avatar
    Jul 2010
    Yeah agreed with allencr- these wiper motors are 40 years old and probably have never been opened up and cleaned once. Take it out and have a look, you'd be surprised what a bit of elbow grease and WD40 will do.
    The Smurf: A 1972 TA22 with a 2TGEU, individual throttle bodies and a bad attitude.
    Junior Member Grease Monkey ta22fan's Avatar
    May 2008
    Old, yes - but they are simple and quite solid little units. Plus, if you think about it - they only get used for a small fraction of the car's time on the road. These units do come up for sale for reasonable dollars from time to time on eBay / Gumtree. There are a few contact details I can give you for 1st Gen parts dealers if you want to ask around.
    Mar 2011
    I have it fully pulled down and the internal wires have all had their insulators go hard/brittle and have perished causing internal shorting. I may be able to slip some heat shrink over the broken insulators and fix them up, and maybe it will work. The mechanical side is easy, I've already cleaned out the grease that had gone hard in the gearbox section and cleaned up the contacts for the return circuit.
    Does anyone have the pin out for the wiper motor plug? since a couple of the wires have perished and i'll have to desolder them off the terminals to slip some head shrink on, i'd like to double check the pin out prior to fitting it into the car.
    thanks all
    SHEPPO..
    Feb 2012
    Wa
    I saw some thing the other day about Camry ones can be used, sv20 or sv25s?
  1. What do I replace a blown 7afe motor with? 4afte?
    By bendev in forum Tech and Conversions
    Last Post: 30-12-2012, 11:12 AM
