Results 1 to 7 of 7
Thread: TPS only 3 wires?
    Jan 2013
    Netherlands
    Default TPS only 3 wires?
    Hello,
    I've bought myself an 4AGE BT 20V and i've completely rebuild it.
    Problem is i'm running way too rich and get a tps error when i connect TE1 en E1.
    I've noticed that some people have 4 wires on their TPS while mine had only 3 wires. The cut harness that came with the engine also had only 3 wires. I bought another harness and that also had only 3 wires. The IDL wire is missing. I didn't have the IDL wire on my 7AFE as well. I'm running a 6-speed ecu that came with the harness.
    Like to hear your opinions.
    Nov 2011
    Default Re: TPS only 3 wires?
    blacktop ecus don't have idle circuit wire
    sometimes ive seen people cut the power to the tps as it runs thru a big plug
    people try to tidy loom up and cut this plug off which has 3 yellow wires and if u cut plug off or if the plug does not have the end on it
    the tps wont have power
    find the vc wire its yellow
    and join it to yellow wire on tps
    Nov 2011
    its also powers up the map sensor
    Jan 2013
    Netherlands
    Okay, i've wired up al 3 wires from the beginning so that wouldn't be the problem.
    The cause is almost certain after this evening. I've measured the primary ignition coil and the resistance is about 0.9-1.0 Ohm. Should be between 0.3x and 0.4x. That would definately explain the rich running.
    May 2010
    Moscow
    onnaj, did you take meter's self resistance into account?
    Dec 2011
    Quote Originally Posted by George View Post
    If the meter is digital it should do it itself, or if analogue you will be able to "zero" the meter.
    May 2010
    Moscow
    inexpensive digital meters (mastech etc etc) will read ~ 0.6 Ohm with their test leads shorted.
  1. Help please! Where do these wires go??
    By aloshan in forum Tech and Conversions
    Last Post: 28-11-2011, 03:01 PM
  2. Replies: 16
    Last Post: 10-11-2007, 05:36 AM
  3. help re-pining ecu wires!
    By sw20r in forum Tech and Conversions
    Last Post: 13-05-2006, 05:42 PM
  4. live wires??
    By rokusan in forum Tech and Conversions
    Last Post: 12-03-2006, 09:32 PM
  5. RB30 TPS - 6 wires - WTF???
    Last Post: 24-10-2005, 01:28 AM
