Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: 4AGZE Gurus Pls Help : Engine developed knocking sound
    Junior Member Domestic Engineer 1200det's Avatar
    Default Re: 4AGZE Gurus Pls Help : Engine developed knocking sound
    Quote Originally Posted by go_the_datt
    slightly off topic but how much roughly to replace all these bearings. genuine and non.
    sorry if this'll dis-hearten the authur. lol
    Very rarely can you get away with just replacing the Big End Bearings , Usually you will have scoring to the Rods and Crank.
    If you have scoring to the crank or rods and you just slap some bearings in you will have the same issues not to long down the track when the scoring grabs a bearing or something.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    May 2006
    For EVOSTi, You have a PM
    Clemmie
    If there's no damage, it's fairly cheap - around $100 or so. Unfortunately, as has been said before there is very rarely no collateral damage...
    what? Automotive Encyclopaedia EVOSTi's Avatar
    4agze's are good engines, but they are 15 years old and thrashed ofcourse some are going to have issues, its not to say they are not a strong engine, mines been running 15psi for years.
    like mentioned, once the big ends start making big noises, youre usually past the point of simply replacing the bearing shells. most likely you will require the crank to be linished and the conrods closed and honed.
    Apr 2012
    I've just had mine 4AGZE rebuilt & from the 1st time it fired up (after a crap load of dramas) it had a similar sound to yours. But mines across the whole rev range & I thought that it must be something in the head as I have Tomei cams in there. But after hearing the sound of yours in your vid, mine sounds a lot like it. I'll take a vid of mine & post it so you can hear & maybe you guys could help me out too.
    Diserter Domestic Engineer
    vic
    My 4AGE sounds like that, it's just the exhaust manifold gasket. $15 on a tube of copper gasket maker will rule it out for you though.
    Oct 2009
    Quote Originally Posted by worldwalker View Post
    Like the sounds clip?
    That's pretty hardcore rod/bearing knock
    Exhaust gaskets make a pretty good ticking noise or a squeel/screech if its a metal gasket.
  8. #38
    vic
    My 4AGE is a little heavier then that and not at the same frequency, a little more of a click but loud enough to hear it down the road. Road worthy inspector picked it first go.
  9. #39
    Apr 2012
    Ok I've just had my GZE rebuilt & I've got 264 Tomei cams & uprated springs along with some head work, pistons, blah, blah, blah & as soon as it cranked over it made a similar ticking noise coming from the valve train or so I thought (still do think it does). Until I saw some comments on here suggesting it might be the exhaust manifold gasket. Now Ive got a sneaking suspicion that might be the case for me. Heres a quick vid, whats your thoughts guys?
  10. #40
    Oct 2009
    Sounds oddly private lol
  11. #41
    Apr 2012
    Quote Originally Posted by dnegative View Post
    What do you mean?
  12. #42
    Oct 2009
    Means your youtube video is set to private lol
  13. #43
    Apr 2012
    Hahaha never mind I figured it out & made it public
  14. #44
    Oct 2009
    Sounds kinda like an exhaust leak
    Worth the hours work to pull off and check the manifold
  15. #45
    Apr 2012
    Thanks bud I'll take a look this weekend if I get the chance
  1. MA70 --> JZA70 Conversion
  2. 4agze engine mounts
    By akmehd in forum Tech and Conversions
    Last Post: 16-05-2006, 11:20 AM
  3. 4AG(Z)E Engine mounts
    By DiZ in forum Tech and Conversions
    Last Post: 05-04-2006, 11:00 PM
