Results 1 to 15 of 26
Thread: 1jz Belt
    Default 1jz Belt
    Hey Everyone
    Just trying to find some information so I can finish my car. What im after is a replacement serpintine serpintine 6V belt for my 1jz motor. Only problem is im not running the A/C compressor anymore so obviously its going to be a shorter belt.
    My mate purchased a belt for this such problem a while ago and doesnt remember the product code for it and he unfortunately sold the car so we cant check the belt itself. It was a stock belt for another car that fitted up correctly.
    So if anyone could help me out, that would be great.
    SImon
    Default Re: 1jz Belt
    easiest way is to get some string and go around the pulleys, measure it with a tape measure and go to local store. That is how I got mine as I have no a/c, p/s, tensioner and alternator is moved to other side.
    QUICKEST 1JZ'S IN OZ
    I think stock is a 6PK1980 or 6PK1984. I want to remove my AC compressor, and I'd love to know the required new belt length. I think I read somewhere that it was a 6PK1900.
    244rwkw / 328hp @ 18psi
    Classic Not Plastic Domestic Engineer ace's Avatar
    Use string or a cut belt to measure then go to supercheap and buy a few around that length, trial and error, and then return the ones you dont need back to supercheap.
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Montrose
    I've done this once on a 1JZ, can't remember what belt I used, but as said, use some string. Anytime I've ever been looking for a belt for an engine parts stores don't know, I use string and have never had a problem yet.
    well i did what u guys recommended and used a piece of string, went into repco and they had a tool to measure and get the correct size. Bought the belt they recommended and it fitted perfectly
    Will post up the model number after i finish dinner
    What belt did it end up being? I just bought a 6PK1900 for when I remove my AC next weekend. If it is the wrong one then I'll have to take it back.
    6PK1000 rings a very very loud bell. Crank pulley, water pump, alternator, and tensioner.
    cheers Chuck
    MS51Crown Coupe,
    S.A
    Quote Originally Posted by Ribfeast
    From what i understand the 1900 is the belt length in mm ,so your belt mabe too long.
    I could be wrong thiough
    Chuck: you mean getting rid of a/c and p/s then. If so, that is what I have and I got rid of the centre tensioner also and the alternator is mounted like normal on a sliding bracket on the bottom passenger side of engine. So it only has to go around h. balance, water pump and alternator. Very simple
    West Australia
    Quote Originally Posted by IRB20
    Would like to know asap plz , as ill be taking my aircon compressor off the engine tomorrow !
    Well I currently have a 6PK1980 with AC compressor fitted. And its approx 8cm shorter without having to go around the compressor (as measured by a piece of string lol), so 6PK1900 should be correct?
    S.A
    Hmm ignore my previous post. I dont know what i was thinking
    For some reason i thought the belt length was 1880 and you went to the 1900 - --- 20mm longer.
    Not the 80.mm shorter.
    I got to stop posting when so tired !
    Quote Originally Posted by chris davey
    I just liked the idea of never ever having to adjust the belt tenion, so left the original in position. Worked a treat, particulary in the '23.
    For the information of others, ribbed belts are identified by the number of ribs,
    ie.6PK= 6 ribs, and the number 1200, or whatever, refers to the circumference of the belt in mm.
    cheers Chuck.
    MS51Crown Coupe,
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    6PK1900
    Ive done the same on my car, came off a Daewoo Nubira i think. Fits perfect.
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
  1. 1JZ water pump rattling...need advice plz :)
    Last Post: 18-01-2007, 08:28 PM
  2. 1JZ Timing Belt Installation
    Last Post: 18-09-2006, 11:19 AM
  3. 1jz vs 2jz heads
