Results 1 to 15 of 30
Thread: 1jz speed signal and wiring questions?
    Apr 2013
    Default 1jz speed signal and wiring questions?
    hi guys, im currently fitting a 1jz and a340e into a volvo 240.
    my question is regarding the 2 speed signal inputs for the trans. i understand one is in the gearbox, and the other in the clockset. they're both 4 pulse per rpm signals. i wont be using the soarer clocks, so how do i generate a 4 pulse per rpm signal? can i tap both input wires into the one sensor?
    finally any info how you guys have done this would be greatly appreciated.
    Default Re: 1jz speed signal and wiring questions?
    SP2, is as you say 4 reluctor (AC waveform) pulses per gearbox output shaft revolution.
    SP1, is 4 pulses (squarewave) per revolution of the speed sensor. The SP1 signal to the engine ECU is the same (effectively) as the gearbox mounted SP1 speed sensor signal, or this SP1 signal is generated in the dash if your auto is driving a speedo cable... However it's worthwhile to note that there is an ~6 (There are also other teeth number gears available...) teethed gear on the gearbox output shaft that drives an ~18 teethed gear that is on the sensor (that generates 4 pulses per revolution)...
    As the SP1 sensor is driven from gears, the gears can be changed as needed by Toyota in the factory to make sure the engine ECU (and dash) gets the correct actual road speed given that the same car might come with different wheel and diff ratio options...(this is handy so that the auto shift points are correct in regards to road speed).
    So you can see that both sensors are 4 pulse per rev, but they arent exactly the same... you wont be able just tap the one sensor for both signals... and you don't need to!
    If your auto gearbox is set up to drive a cable speedo, then simply change the cable drive for an electric speed sensor at the gearbox.
    If you don't have a dash that needs the SP1 signal then you can simply wire the output of the SP1 speed sensor to the engine ECU and it will work correctly
    Apr 2013
    im using a jzz30 donor, so no speedo cable. as i read it, the ecu uses the trans sensor, and only uses the dash as a back up, on which case, can i just wire the trans one and leave the other disconenected?
    or am i being too simple?
    finally i have some wires not on your list..
    pin 9 of the orange plug i have a yellow with a green stripe and 2 silver spots. your list says this pin is blank
    pin 14 of orange plug i have a green with white stripe and 2 silver spots, its not listed
    pin 8 of white plug is yellow with a black stripe and 2 silver dots. its not listed.
    pin 13 grey plug p/n 90980-10813 is white with black trace, and 2 silver spots. its not listed
    any ideas?
    sorry for the questions...
    Nov 2011
    u dont need the sp1 signal for the auto to change gears
    as long as sp2 is hooked up properly so if u dont cut the wrong wires sp2 will work
    anyway many years ago i looked at relationship between rotation of speedo cable and rotation of outputshaft on a 1uz box
    i think u need to turn outputshaft about 3.1 to 3.3 turns to get cable to spin once
    Apr 2013
    anyonegot any ideas on the wiring? nearly made my loom and relays apart from those wires....
    Nov 2011
    yellow green is normally water temp gauge wire
    yellow black is normally oil presusre light or gauge wire
    white black is normally an earth
    Apr 2013
    green white is auto drive light crap
    http://www.toymods.org.au/forums/tec...ring-help.html
    thanks guys.
    Nov 2011
    why do u need to hook up green white if its on the shifter
    was yr car originally manual
    green white can also be brake signal to ecu
    Apr 2013
    Quote Originally Posted by dumbass View Post
    no both are auto. i dont need it, so ill remove the wire from the plug.
    Apr 2013
    righto im left with one wire.
    ik2, white plug, i have a yellow/black in slot 8. there is no reference to this anywhere.does anyone have an idea?
    Nov 2011
    how fking hard is it
    get a multimeter and prob the wire
    we r not going to spoon feed u hehehehe
    like i said it might be oil pressure
    otherwise check diagnostic plug
    but i dont know any other yellow black other than oil pressure
    Apr 2013
    how is asking for help with one wire being spoon fed? i thought that was the point of a forum. i dont own a multimeter so testing continuity isnt an option.
    thanks anyway.
    Apr 2013
    oh and it isnt oil pressure.
    Nov 2011
    Heheh
    Well u should goto toymods favourite gadget shop
    And show your toymods discount card and buy a 5 dollar multimeter
    And a test light
    They are a must when dong conversions
    I'd hate to see the quality of the job if u don't have proper tools heheheh
    Nov 2011
    Anyway in my proper diagrams
    Pin 9 orange plug green yellow is te2
    Green white pin 14 is "D". From inhibitor
    The yellow black supposedly goes to pin 29 on the ecu
    And in one of my diags pin 29 is "CCO"
    I have no white black on my grey plug diagram
    But pretty sure it will just goto ground
  1. 4AGE 100kw Speed signal
    By Grega in forum Tech and Conversions
    Last Post: 28-04-2008, 03:36 PM
  2. RT142 speed signal
    Last Post: 27-02-2008, 06:27 PM
  3. Help please! Need to find speed signal wire
    By iSOARu in forum Tech and Conversions
    Last Post: 23-09-2007, 08:38 PM
  4. 20valve speed signal
    By rob20v in forum Tech and Conversions
    Last Post: 30-04-2007, 07:35 PM
  5. apexi RSM speed signal?
    Last Post: 27-03-2006, 07:24 PM
