Results 16 to 30 of 30
Thread: 1jz speed signal and wiring questions?
    Nov 2007
    Default Re: 1jz speed signal and wiring questions?
    You need to buy a Multimeter especially when you don't know what wires do what.
    Also don't worry about random wires that you don't know what their function is off your Soarer loom, many of those will be for ABS, TRC etc on the Soarer
    that you don't require to have the motor to start and run.
    Bring it to Perth and I'll wire it in for you haha
    Nov 2011
    hey z2tt where did u get those two 1uz vvti ecus from which i got of you afew months ago
    i need 1 or 2 more
    ive figured how to get the security bypassed using afew things but i want to step it up to the next level
    and ive got a new test i need to try on afew more to see if ive cracked the immobiliser so there is no need for any parts
    just a reflash of the ecu and it should run with none of the security wires connected
    i can get some from usa as a last resort
    thanks
    Sorry it seems I didn't subscribe to the thread... anyway.
    Did you not read this? I believe this applies to you.
    I'm pretty sure the check engine light will come on if you do not have SP1 connected. This is not ideal.
    Quote Originally Posted by wilbo666 View Post
    If you don't have a dash that needs the SP1 signal then you can simply wire the output of the SP1 speed sensor to the engine ECU and it will work correctly
    As the others have said, buy a multimeter.
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2011
    I just fit a toggle switch on the check engine light wire
    if the speedo does not have provisions for signal back to ecu
    also only afew models have correct four pulse signal on gbox
    for speedometer this can go directly to ecu
    but most Toyota have a 20 pulse which is not a good idea to
    run to ecu directly as its to fast a speed signal
    but your gbox will work fine without sp1 connected
    just check engine light will come on after afew Kms of driving
    but I have had some ecus not bring on check engine light when no sp1
    Quote Originally Posted by dumbass View Post
    also only afew models have correct four pulse signal on gbox for speedometer this can go directly to ecu
    Yes if you have a 20pulse / rev electric speed sensor it won't work connecting it directly to the engine ECU.
    All the xJZ stuff is 4 pulse / rev if I am correct...
    I do know UZS131, MX83 and MZ12 are 20 pulse / rev however...
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2011
    Crown 1uz are 20 pulse
    Cressida and chaser early are 4 pulse
    That's y I used to collect Cressida speedo sensors for the four pulse
    Hilux and landcruiser are four pulse
    Corollas and mr2 are four pulse
    Most others are 20
    Jul 2013
    hi, in the process of building a mx83 cressida with 1jzgte and a w55 gear box. Having trouble finding a way to change from a cable driven speedo to a speed sensor any help would be very much appreciated
    Team Thrash Garage's Grease Monkey VikingDrift's Avatar
    victoria
    Old thread, but does anyone know if 88 ma70 is 20 pulse? Originally 7mgte now jzz30 1j and autobox with mx83 rear ext. housing to suit mount. Speedo cable keeps breaking so i tried putting a jzz30 sender into the box and wiring the output to the digi dash but it reads way slow.
    Apr 2011
    jzz30 sender is 4 pulse.
    use a z20 sender, they are 20 pulse. you will need to put the cable drive back on though as they screw onto it.
    victoria
    Haven't got enough room for that style as the mx83 housing puts it on passenger side and ma70 housing is proving difficult to find. Almost considering jzz30 electronics to run the ma70 digi dash.
    Apr 2011
    get a dakoda digital sgi-5 then. can convert pretty much any speed signal to any speed signal.
    i have a ga70 auto box lying around you could buy the extension housing from?
    victoria
    Ok do you reckon the jaycar one will work? Also got a pic of the rear extension housing?
    RT-142 daily drifter, now JZT-142 , projects: hk prem, 40series cruiser, MX-22
    Apr 2011
    jaycar one will work as long as it can multiply by 5.
    i havent got a pic but its was removed from a GA70 supra so will be on the drivers side.
    victoria
    Didn't even pick up the signal, i tested it at the input of the converter at a crawl multi went 0v, 5v, 0v, 5v, etc. Rest of wiring was fine nfi. Ok cool just wanted to make sure with a pic as we looked it up on toyodiy and the extension housing part number only showed up as ma70 not ga or jza
    Apr 2011
    ill double check when i get home tonight. is from an s2 a70 so will have the hole for the 2nd 2 wire speed sensor.
  1. 4AGE 100kw Speed signal
    By Grega in forum Tech and Conversions
    Last Post: 28-04-2008, 03:36 PM
  2. RT142 speed signal
    Last Post: 27-02-2008, 06:27 PM
  3. Help please! Need to find speed signal wire
    By iSOARu in forum Tech and Conversions
    Last Post: 23-09-2007, 08:38 PM
  4. 20valve speed signal
    By rob20v in forum Tech and Conversions
    Last Post: 30-04-2007, 07:35 PM
  5. apexi RSM speed signal?
    Last Post: 27-03-2006, 07:24 PM
