Results 1 to 8 of 8
Thread: Valeo Brand Clutches - anyone used them
    Dec 2009
    Default Valeo Brand Clutches - anyone used them
    Hey all,
    I bought a clutch by the brand of Valeo and i'm wondering if i've made the right decision. I was working with my limited funds at the moment and bought this clutch. Its a huge job doing a clutch install on a Caldina GTT so i'm wanting to get it right first go. As a result I may end up seeing if I can get the clutch swapped over for an Excedy Heavy Duty Clutch.
    Toyota Celica CLUTCH KIT Year Apr 1994 & Onwards ST205 GT4 TYK23604
    Thanks all
    ZZT-231 Toyota Celica SX
    oregon
    Default Re: Valeo Brand Clutches - anyone used them
    What ever you get.... get it balanced.....
    This is an OEM Toyota pressure plate... after it got balanced
    Junior Member Grease Monkey stealth's Avatar
    Jul 2012
    Valeo is the std brand for alot of jap manufacturer's clutches so they're not a knock off brand.
    my old Nissan had a Valeo stamp on the pressure plate and disc, and I believe my 1JZ's disc had it too... So what you've bought is probably pretty close to a genuine Toyo clutch.
    If I was you and the clutch is a prick to do, I'd be getting more than a standard kit, get a HD at least if you can afford it. ol mates advice on getting it balanced is good too!
    JZA63 Celica 13.9 @ 162km/h
    Jul 2012
    Oh and do every seal you can find while the box is off!
    Traditionalist Domestic Engineer parrot's Avatar
    Valeo is a huge French company.
    Once upon a time they were called Ferodo, so it should be a pretty good clutch!
    Cam mountain I feel different from the ordinary
    Dec 2009
    thanks for the feedback. In the back of my mind i'm really tempted to buy an Exedy clutch instead. I believe the Valeos were manufactured in Korea.
    Its interesting i've never balanced a clutch pressure plate in my life. Would it make a big difference?
    oregon
    Quote Originally Posted by trd_st184 View Post
    It depends.... but look at how much material was removed from the stock pressure plate.... now imagine that imbalance @ 5k, 6k, 7k rpm.........
    Dec 2009
    Thats true. I would have thought the pressure plates may have been machined from factory (or at least the design was balanced).
    Would the clutch also require alignment too?
    Its interesting i've never actually done balancing before. Mind you, my uses have always been pretty low spec power.
  1. ebay clutches....
    By sandman in forum Tech and Conversions
    Last Post: 30-01-2010, 11:39 PM
  2. sc12 clutches etc..
    By feral4mr2 in forum Tech and Conversions
    Last Post: 29-03-2007, 03:09 PM
