Results 1 to 15 of 17
Thread: sc12 clutches etc..
    Default sc12 clutches etc..
    been a while since i've posted a thread here....
    i've got a map sc12 with the 120mm pulley on it, swapped it over with the afm 125mm pulley sc12 in the lil feral yesterday. the s/c is noisey at idle, but it still boosts well (specialy combined with the 175mm crank pulley).
    i was about to pull it out tonight and put the old one back in, was going to put the 120mm pulley onto the original s/c.
    i gather the early and late sc12's snout doobie is the same and clutched pulley assy is interchangeable?
    i drained the oil and on the lil magnet doobie on the drain plug there was metal filings.
    but when i went and looked at my original one it had metal filings on the drain plug too.
    as i was pulling stuff off i noticed after removing the belt that the outer pulley on the s/c was noisey when turning it. hrm... i pulled the little plate doobie off the front and tried to see in. hooked the belt bacl up and started the car. when i earth the wire on the s/c clutch so it's locked on the s/c is much quieter. there still is a little noise from the s/c but bugger all. take the earth off so it free spins again and there that damn noise!
    is there a bearing or something in the pulley assy that can fail? the noise now to me is all from the pulley assy, not the s/c itself like it thought...
    does anyone have a breakdown pics of the map s/c pulley assy?
    as i might be going to perth this saturday i might lock the s/c clutch on and put the abv back on.
    thanks.
    Default Re: sc12 clutches etc..
    There is a large bearing in the outer pulley, I'd be fairly surprised if it failed. One the plus side, they are a bearing you can buy (I think I get one for about $30 or so). It's probably just got some crud build up inside the assembly.
    Have a look around www.mr2oc.com there used to be exploded pictures from Toyota on the site last time I looked. It might just need a good clean out.
    Junior Member Conversion King deviant's Avatar
    wa
    What kind of noise is it mate?
    When I drive my car there is a ticking noise with engine speed that starts at around 2-2500RPM....It starts before the SC light comes on, on the dash. Its quite loud but is not there when it is idling...only under load.
    I was hoping it would just be a tensioner that is on its last legs but I'm not all that convinced anymore!
    How long you going to be in Perth for? AW11 meet up FTW!!
    Quote Originally Posted by S2K
    Would a VTEC limiter be a helpful device?
    this dosent really show it well but insude 17067 there is a bearing in there. that does get shagged i replaced slipstreams a few months ago.
    it's a horrid rumbling type noise, made it embarrasing to drive out of the shed for a test drive.
    it doesnt sound like something that's caused by a crud build up, bit deep a noise for that.
    thanks for the pic toof.
    i might be heading up to perth on saturday (would like to go this arvo, but doubt i'll be ready), there's a cruise on sunday i'm interested in going on. i have to be on site monday morning for night shift that night, so it'll be a early start monday morning to drive to site.
    looks like i'll just manualy lock the clutch for now, pull it all out next break and get a new bearing from my uncle (has a bearing shop).
    does anyone else notice a metal buidl-up on their drain plugs?
    yup if its a constant rumbling noise thats what it sounds like when that bearing gives up.
    damn it. got a switch wired into the neg trigger of the clutch so i can have it run all the time. s/c is still noisey, i'm sure last night the noise basicaly went away when i engaged the clutch. but then it was late and i was tierd.
    too bad, i want to go to perth tomorow. i guess if it seizes or something sinister i'll have to just let it run on the clutch and unplug it.
    Oberst Koi-Master Backyard Mechanic
    mine makes a scraping, grumbling noise when engaging low in the revs, and when it disengages...
    seems worse now than a year ago, i think it is crud build up as above.
    Can you get a recording?
    "Welcome the dude who ain't the buyer of mugs"
    i could of today, was thinking about it earlier. cars nearly all packed for the trip to perth now.
    i'll put my old one back on when i get back from work in a fortnight, should just get my ass into gear and do the twincharge i was originaly going to do.....
    working hard Backyard Mechanic
    Feral how do you take the pulley off ?? there is 3 clips the face of the thingo where the pulley free spins which i dont wanna break taking off.
    Junior Member Domestic Engineer mic*'s Avatar
    Feral, the bearing inside the pulley is in action constantly because it runs on the boss which bolts to the SC housing - always stationary. So i wouldnt think you should get a noise which comes and goes from that bearing.
    The bearing at the front of the SC on the clutched lobe is a possible culprit - it is loaded when the engine breathes thru the SC - like when you free rev it under the bonnet.
    Reece, from memory there is a cap which has screws retaining it to the clutch face, then one bolt and a surclip. Then the clutch face comes off.
    meh...
    From the pic i gave there is no screws holding it down. Just thoe 3 things on the clutch plate. Really wanna take pulley of without force
    reece, it's been a while since i pulled the clutch set-up off a sc12, but i am sure there is a center circlip or large nut that holds on the part you have pictured.
    mic, the s/c itself is shagged. and the bearing noise from the clutch is constant, wether engaged or not.
    i've put the old s/c back on now. i guess oneday i'll pull the shagged one apart and have a looksee at it all, my uncle owns a bearing shops....
    Quote Originally Posted by feral4mr2
    The center nut has been taken off, just cant find no circlip or find whats not letting it come out
  1. Exedy (Daikin) and Paraut Clutches
    By Tham in forum Tech and Conversions
    Last Post: 12-09-2007, 09:15 AM
  2. SC12 on a 22r
    By charged22r in forum Tech and Conversions
    Last Post: 11-11-2006, 01:14 PM
  3. Small upgrade - SC12 onto 7AFE
    By birdie in forum Tech and Conversions
    Last Post: 18-10-2006, 10:32 PM
