Results 1 to 8 of 8
Thread: 1.5jz into z20 soarer using jza80 loom - running eye burning rich
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default 1.5jz into z20 soarer using jza80 loom - running eye burning rich
    hey guys have just fired up my titan spec 1.5jz specs as follows:
    1jz head, port work, o/s valves, ti springs retainers, 264 cam 9.5mm lift, gates cam gears
    2jz bottom end , 86.5mm JE pistons, manly rods, acl bearings
    jza80 loom/ecu, running OEM stock injectors, stock fuel pressure although running 044 fuel pump
    as i am trying to run my cams in for the first time the car is running insanely rich, as in it will fill up the shed with fuel smoke within a few minutes of running, and the manifold starts to glow RED at only 2000 rpm... any ideas what i have missed?
    i understand it will be richer as im using a stock ECU and bigger cams, but ... black smoke just POURS out the back
    have just wired in a new 3 wire o2 sensor and it doesnt seem to change anything.
    map sensor is connected
    Another thing to mention is im running an r34 TPS sensor , with a universal type throttle body, could this be a factor ? it idles/revs smoothly
    any help much appreciated.. just want to get it running well enough to drive it!
    87' z20 Soarer - 1jz Gt35r -
    Nov 2011
    Default Re: 1.5jz into z20 soarer using jza80 loom - running eye burning rich
    I love it how u spend heaps on engine and nothing on electronics
    Keep up the good work
    TAS
    the reason behind the stock ecu and injectors is for run-in... once the 1000kms is done a haltech 2000 and 1600cc injectors are going in.
    but if i cant get the stock ecu running how i want ill have to buy the haltech now rather than later..
    BK Grease Monkey bk_'s Avatar
    Toyota OEM ECUs (atleast pre-1996 JZ) utilise a combination of alpha-n and speed-density tables.
    Thus, if you connect up a Nissan TPS, injection will be completely off, because the resulting TPS voltages will be off.
    Nov 2011
    99% of tps's are 0.5 to 4 volt so that should be fine
    He doesn't have idle contact but that should not make it run rich
    Even without map sensor should not make it run so rich
    Something has changed like injectors are way to big or something stupid we are not told about
    Maybe u have cranking signal to ecu always on
    Even that should not make it run that rich
    Drop fuel pressure to 30 or 20 psi see what it does
    Unplug all sensors except for ones to make it run
    Unplug maf. Map. Tps. See if it helps
    TAS
    Bit of an update if i bridge the 2j idle switch to the nissan tps output it runs like a dream
    But as soon as you blip the throttle it coughs and dies.. If theres no way to rig up a switch of my own ill have to buy a new tps
    Any jz experts? Cheers
    From what you have said in your PM, I think the easiest thing is to either
    1) Get / fit a TPS that has an idle switch built in
    or
    2) Fit a small micro switch (i.e. check out what jaycar have) to trigger the idle signal
    Wilbo's JZA80
    Wilbo's JZZ12
    TAS
    Cheers for your reply wilbo, turns out it wasnt Tps related at all
    1. Map signal was cut to ecu
    2. The 5th and 6th injector wiring had been swapped (chopped loom)
    Making it backfire and carry on
    Pain in the ass but its all sorted now.
  1. 1uz running rich/ rough
    By KLR16V in forum Tech and Conversions
    Last Post: 18-03-2013, 09:46 PM
  2. 1jz gte (jza70) running rich
    By milos1990 in forum Tech and Conversions
    Last Post: 20-03-2010, 12:22 PM
  3. 5M Running Rich
    By Glenno52 in forum Tech and Conversions
    Last Post: 25-05-2009, 01:26 PM
  4. 7MGTE: Running after accident but still burning oil
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 28-12-2008, 10:55 AM
  5. Running rich?
    By joey in forum Tech and Conversions
    Last Post: 26-02-2007, 08:42 PM
