I take it you pulled the gearbox apart to fit the MA61 shifter position? Did you by chance loose a spring or ball for the shift detents, not that you need to remove these to swap shifter positions but there could be a chance they are missing or broken. Though now that I think of it, since 1/2, 3/4, 5/R share the same shift arms and the back gears work, maybe there could be some wear on the shaft detents themselves.
If you havent already, check out the TSRM on p9 for the exploded view, the ones I am referring to are in the middle pic and should be on the side of the sandwich plate - http://www.supras.org.nz/techinfo/TSRM/14_MT.pdf (for a MA70 but has a W58 section, plus R154 if you ever go that way)
			 W58 won't stay in first, third or fifth- stick pops out? Help?
