u cant use ressitance to test wires when all the sensors are plugged in
it will give u false reading
efi relay power goes to ecu and the idle motor power and to o2 sensor power
ignition switch power goes to coil and injectors power
u need to have power when on run and crank
anyway sounds like yr wiring is in a bit of a mess
wire it up porperly
power to all places
wire up check light
then u wont fk around for 3 days going round in circles
i dont know what exactly u have wired up or what parts u have used as u havnt given us a proper explanation
anyway best of wire up original ignitor and coil
this way u can rule that out
a silvertop ignitor has big number 201 on it
a black top has CDH1 or something similar
sounds like your setup up is like a mongrel dog
a Bitsa hehehheeheh
				 Re: silvertop with blacktop ecu
