Results 1 to 11 of 11
Thread: 30-40LS / A304E (VVTi 2JZ) auto info
    Jan 2007
    queensland
    Default 30-40LS / A304E (VVTi 2JZ) auto info
    Hi guys,
    Not sure what this box is from, was told it was from a JZ that's about all he could tell me ???
    Has J bellhousing, is plate on the box tag is 30-40LS
    There are some numbers and serial numbers if that helps but that was all I wrote down.
    From what I can find, these boxes were on the VVti jz only? No lockdown cable, full electronic.
    How can I confirm it was from a turbo/NA?
    Thanks.
    Mat
    Default Re: 30-40LS trans identification?
    The part number is on the plate next to the model number
    This should tell you what it is from
    Jealousy is a curse
    Jan 2007
    queensland
    part number 35000-3F450 google and Toyot DIY confirm from a JZS161 2JZGTE, perfect! wanted to make sure i didn't have an NA box for the project
    Jan 2007
    queensland
    Default Re: 30-40LS / A304E (VVTi 2JZ) auto info
    changed topic title a little rather than creating a new one..
    Are these boxes better/worse than traditional older style from JZX81's etc with kick down cable, just as strong? stronger? better?
    What are you using to control the auto?
    FYI, I'm pretty sure the VVTi 2JZGTE auto has extra solenoids than even the normal 2JZGTE auto
    Wiring diagrams for JZS161 (and it's gbox) are on my wiki.
    Wilbo's JZA80
    Wilbo's JZZ12
    Nov 2011
    I've wired up a 2jzgt with a 4 speed auto before
    We thought it was a five speed but ended up only having four speeds
    In my 2j vvti book is does have info for a four speed
    So I think the early ones are four speed later ones are five
    I guess a pic of the solenoid plug will show us what speed it is
    vic
    All the auto 2JZ GTE vvti,s that I have seen have a A340 and have 7 solenoid s with a 12 pin plug on the side of the box .
    As to why or what the extra solenoid s do I would like to know .
    Dave
    Nov 2011
    extra solenoids are the tap up tap down shift solenoids
    It should have S1, S2, SLU (Lock up) and two PWM solenoids.i.e. Line pressure and accumulator back pressure.
    The last two usually are not earthed in the gearbox and both + and - connections come out at the solenoid connector on the side of the box. That makes 7 wires for 5 solenoids in total.
    Jan 2007
    queensland
    Pics attached, thanks for the info.
    i have no ECU, wiring etc etc.. so i am up for any options, i didn't even know what this box was from untill recently..
    cheers,
    This may help
    Jealousy is a curse
  1. W55 auto trans to w50 manual trans conversion
    By remo80s in forum Tech and Conversions
    Last Post: 11-09-2011, 08:57 AM
  2. W5# identification
    By jdm86gtz in forum Tech and Conversions
    Last Post: 13-01-2011, 03:56 PM
  3. 3T-GTE Cam identification HELP!
    By toyo-al in forum Tech and Conversions
    Last Post: 28-04-2010, 07:23 PM
  4. W5x identification
    By sammyp in forum Tech and Conversions
    Last Post: 24-09-2008, 09:08 PM
  5. DIFF identification
    By Muziiz in forum Tech and Conversions
    Last Post: 09-08-2007, 07:33 AM
