Results 16 to 19 of 19
Thread: xtreme carbon clutch question?
    Forum Contributor Domestic Engineer
    Default Re: xtreme carbon clutch question?
    Quote Originally Posted by pete05 View Post
    I have a very large ct26 hybrid turbo waiting to go on and would like to have faith that the clutch will hold.
    Can I ask for a bit more detail on what have you got turbo wise, and is the 250kw you suggested earlier an accurate estimate?
    MA71 - 7MGTE - 340RWHP
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Quote Originally Posted by boxh34d View Post
    Hey yeah, turbo is T04 core with CT26 comp and turnine cover, but with a T04 P Trim turbine and T04B Super V Trim Comp wheel and a ported waste gate. I also have a full 3 inch mandrel bent exhaust, 550cc injectors a lexus air flow meter ,electronic boost controller and a safc. So the plan is with a healthy amount of boost it should make 250 at a guess. I just need to get the clutch done and a bigger fuel pump.
    Hmmmm. I would suggest you could probably be looking at more than 250 with that setup. If I can make 255 with the same comp wheel, but the standard CT26 turbine, then you should be able to get a bit more with the much better flowing P trim turbine wheel.
    As I said earlier, I have NFI about the carbon clutches and what they are capable of holding, but it might be best to err on the side of caution and spec if for 300 to give yourself some room to play with.
    penrith nsw
    I Think the carbon is about the best I am going to get in a single plate and still keep it reasonable to drive, if I find the limit of the clutch is only 250 then I am happy to leave it at that power level, its more than enough power for the street for me.
  1. xtreme carbon clutches
    By fixeruperer in forum Tech and Conversions
    Last Post: 30-07-2009, 07:32 PM
