Results 16 to 21 of 21
Thread: Trouble removing bearing inner race - independent rear axle
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Default Re: Trouble removing bearing inner race - independent rear axle
    we use a gear puller or what ever there called, the three claws thing, and you put a socket on it and turn it, it pushes the centre down as it pulls the race up. Used it 3 times for gt4 bearings
    Current: 1990 ST185R Celica:
    http://www.toymods.org.au/forums/showthread.php?t=62315, DAEWOOOOO ESPERO
    Previous: Ta22 4aGZE; Older: 99' WRX Impreza 192kw
    Jan 2007
    queensland
    i'd suggest just heating it up with the TIG, strike an arc on it to get it to glow, then a few taps with a chisel.
    It is done. Thanks all
    Jun 2008
    Great, but what method did you use?
    This:
    I didn't trust that it would have enough contact under the race to pull it up without slipping or breaking, but it was so simple in the end that you'd think it was easy enough to do with your bare hands
    Jun 2008
    It's because it is being pulled evenly and does not rock such that it wil jamb.
  1. Trouble removing 2T timing cover in TA22
    By ToyTA22 in forum Tech and Conversions
    Last Post: 19-06-2011, 06:20 PM
  2. How to remove wheel bearing inner race from stub axle?
    By bobbymitchell in forum Tech and Conversions
    Last Post: 22-10-2010, 04:02 PM
  3. Removing axle bearings, T-series...HELP
    By newbien in forum Tech and Conversions
    Last Post: 20-04-2009, 02:14 AM
  4. replacing axle bearing ??
    By sam-131 in forum Tech and Conversions
    Last Post: 03-07-2006, 07:57 PM
  5. rt142 independent rear = ra65/sa63 celica
    By Mattrt142 in forum Tech and Conversions
    Last Post: 26-02-2006, 12:48 PM
