Results 1 to 3 of 3
Thread: vvt 1jz gte at to mt problems
    Mar 2010
    UK
    Default vvt 1jz gte at to mt problems
    Hi all,
    i heard about that when you convert a 1jzgte at to 5 speed manual, you can use at ecu, but it will happen the idel funny and also
    car will stall sometimes.
    anyone have this experience?
    many thanks
    Aug 2009
    Default Re: vvt 1jz gte at to mt problems
    adjust the idle screw a little higher on the throttle body , i found it helped
    and also bridged the wires that are for second gear and soldered them together and removed dash light as it made more sense to me
    for it to thinks its in gear rather then neutral
    after that never had a stalling or idle problem ever ,even later with aftermarket turbo setups ect or even without the j pipe
    May 2010
    Moscow
    you may fool ecu, make it think it's always in park/neutral. Then it won't have idle issue, and it won't store transmission related failure codes. Power output won't suffer from that
  1. having problems with p.m's
    By Slidin23 in forum Forum Troubleshooting & feedback
    Last Post: 17-09-2010, 07:21 AM
  2. Help me figure out my clutch problems [More problems!]
    By Hash_ra23 in forum Tech and Conversions
    Last Post: 23-10-2008, 06:14 AM
  3. 1jz problems
    By JapTastic in forum Tech and Conversions
    Last Post: 29-06-2007, 09:45 AM
  4. A Few Problems
    By racespec in forum Toymods Car Club Membership and Feedback
    Last Post: 02-02-2006, 03:44 PM
