Check your oil pressure at idle. I put it in one of the threads, but I am old and forget what thread it was in. Also check it at the other RPMs that were specified in that thread. We need to know if it is well in spec or on the limit.
Also it would be interesting to see what the diff in pressure is between cold and hot. You may need to have a different (more viscous) oil - though it would be better to ensure the oil pump is okay before applying a "bandaid" fix on a nice rebuilt engine by using thicker oil.
If your oil pressure is barely within the acceptable limits, then I'd say you need to be pulling apart your oil pump and check the tolerances. It may be getting old and worn (like me) and unable to maintain the required pressure.
seeyuzz
river
