Put me down as interested.
Hi Guys,
MRP 4age/7a Billet Steel Crank Girdle.
Crank Girdle
Billet EN10025 Structural Steel
Electroplated Black
Comes with Longer ARP main studs (can be used with 4age ARP ones without the washers)
Lowers the sump down 7.5mm
Works with 4age OEM windage tray and 4age Sump
Does not work with 7afe sumps
Dual sump pattern to fit 20v/16v and 7a blocks.
RRP $550NZD
If any one wants to jump in early we are offering a special price of $520NZD incl the longer ARP main stud kit.
How to order:
1. Pm
2. Email us - [email protected]
We take Paypal and credit card
Now 9AGTE 410kw atw
www.billzilla.org
Toymods founding member #3
quick question, you say it doesnt fit 7A sumps but if you were to fit a 4ag sump (16v or 20v) it will be fine?
TEC ARTS make a 4A sump to 7A block adapter, so if this is possible i would also be very keen.
N/A for life...
Hey, the 7a sump doesnt fit as the ARP bolts will hit the rear of the sump before you can fully bolt it up.
You can either modifiy the sump by cutting holes where the arp studs stick out and then welding a section over it to clear.
The tec art thing is just a sump spacer so the windage tray clears the crank. Our girdle also acts like a sump spacer so the 4a windage tray clears the crank.
Fitting a 4a sump is the better option as there is no mucking around plus you get a windage tray. Where the 7a sump doesn't have any windage tray.
Hope that clears everything up for you.
Now 9AGTE 410kw atw
adam just do what im doing and get the moroso sump and use a stock 4A windage tray
oh yeah, im down for one of these girdles as you know baz... EDIT: 20V/7A style![]()
Barry
Put me down for one as well...interchangable between my 7agte and the 9agte....
Toyota Trueno GT Apex - AE101, Subaru Legacy B4 - BE5, Ford Galaxie - 1965, Toyota Landcruiser 200series, Honda CBR 250RR, Mazda RX7 FC3S, Toyota Levin GTZ - AE101, Holden Commodore SS - VX
Now 9AGTE 410kw atw
What is the purpose of the 'cutouts' on the underside of the 'main cap areas' where the studs go through?
== 4AGZE SC14 Supercharged ==
Now flogg'n the SC14 @ 18psi....
I assumed it's to allow room for the nuts to be torqued down on the bearing cap, then the girdle sits over these with it's own nut securing it to the main studs. Then the girdle would support the bearing cap rather than taking the whole load and potentially messing with torque settings etc... ????
Now 9AGTE 410kw atw
Sorry for the delay on these guys, have alot of 4age projects on at the moment.
I brought a new PC as i updated my CAD software which needed more power. Should have it up and running shortly to finish off the design and pump out a prototype in a few weeks!
Now 9AGTE 410kw atw
Registering interest. Pretty much 100%. Was going to get the tomei ladder kit but this is even better. Post up once these are completed!
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
Drawings have been approved by our machinist now awaiting the first sample to do checks!
Now 9AGTE 410kw atw
Updated, only 4 weeks away now. Place your orders now as we only have limited stock and we already have alot of pre orders!
Now 9AGTE 410kw atw
www.billzilla.org
