Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: MRP 4age Crank Girdle Billet Steel
    Jul 2008
    Auckland
    Default MRP 4age Crank Girdle Billet Steel
    Hi Guys,
    MRP 4age/7a Billet Steel Crank Girdle.
    Crank Girdle
    Billet EN10025 Structural Steel
    Electroplated Black
    Comes with Longer ARP main studs (can be used with 4age ARP ones without the washers)
    Lowers the sump down 7.5mm
    Works with 4age OEM windage tray and 4age Sump
    Does not work with 7afe sumps
    Dual sump pattern to fit 20v/16v and 7a blocks.
    RRP $550NZD
    If any one wants to jump in early we are offering a special price of $520NZD incl the longer ARP main stud kit.
    How to order:
    1. Pm
    2. Email us - [email protected]
    We take Paypal and credit card
    Now 9AGTE 410kw atw
    Default Re: MRP 4age Crank Girdle Billet Steel
    Put me down as interested.
    www.billzilla.org
    Toymods founding member #3
    loves hi RPMS Backyard Mechanic
    quick question, you say it doesnt fit 7A sumps but if you were to fit a 4ag sump (16v or 20v) it will be fine?
    TEC ARTS make a 4A sump to 7A block adapter, so if this is possible i would also be very keen.
    N/A for life...
    Jul 2008
    Auckland
    Hey, the 7a sump doesnt fit as the ARP bolts will hit the rear of the sump before you can fully bolt it up.
    You can either modifiy the sump by cutting holes where the arp studs stick out and then welding a section over it to clear.
    The tec art thing is just a sump spacer so the windage tray clears the crank. Our girdle also acts like a sump spacer so the 4a windage tray clears the crank.
    Fitting a 4a sump is the better option as there is no mucking around plus you get a windage tray. Where the 7a sump doesn't have any windage tray.
    Hope that clears everything up for you.
    Now 9AGTE 410kw atw
    Jul 2007
    adam just do what im doing and get the moroso sump and use a stock 4A windage tray
    oh yeah, im down for one of these girdles as you know baz... EDIT: 20V/7A style
    Forum Member Grease Monkey ap7's Avatar
    Barry
    Put me down for one as well...interchangable between my 7agte and the 9agte....
    Toyota Trueno GT Apex - AE101, Subaru Legacy B4 - BE5, Ford Galaxie - 1965, Toyota Landcruiser 200series, Honda CBR 250RR, Mazda RX7 FC3S, Toyota Levin GTZ - AE101, Holden Commodore SS - VX
    Jul 2008
    Auckland
    Quote Originally Posted by ap7 View Post
    Barry
    Ok noted down, yes will fit both.
    Now 9AGTE 410kw atw
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    What is the purpose of the 'cutouts' on the underside of the 'main cap areas' where the studs go through?
    == 4AGZE SC14 Supercharged ==
    Feb 2010
    Auckland
    Quote Originally Posted by nick.parker View Post
    I assumed it's to allow room for the nuts to be torqued down on the bearing cap, then the girdle sits over these with it's own nut securing it to the main studs. Then the girdle would support the bearing cap rather than taking the whole load and potentially messing with torque settings etc... ????
    Jul 2008
    Auckland
    Note: The picture is upside down. So turn that around and those pockets are for the main stud nuts and washers to sit into.
    If the pockets are not there the studs would need to be even longer and would foul on the windage tray.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Sorry for the delay on these guys, have alot of 4age projects on at the moment.
    I brought a new PC as i updated my CAD software which needed more power. Should have it up and running shortly to finish off the design and pump out a prototype in a few weeks!
    Now 9AGTE 410kw atw
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Registering interest. Pretty much 100%. Was going to get the tomei ladder kit but this is even better. Post up once these are completed!
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Jul 2008
    Auckland
    Drawings have been approved by our machinist now awaiting the first sample to do checks!
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Updated, only 4 weeks away now. Place your orders now as we only have limited stock and we already have alot of pre orders!
    Now 9AGTE 410kw atw
    Quote Originally Posted by Billzilla View Post
    Put me down as a confirmed order.
    Fixed......
    www.billzilla.org
  1. 4AGE main bearing cap failure - billet option
    By toddw in forum Tech and Conversions
    Last Post: 17-02-2011, 11:09 PM
  2. Forged or Billet 4340 Crank /vs./ Machined OEM Crank
    By Radar in forum Tech and Conversions
    Last Post: 13-09-2009, 03:25 PM
