Results 1 to 12 of 12
Thread: 4A-GZE Clutch and flywheel compatibility
    May 2012
    Default 4A-GZE Clutch and flywheel compatibility
    Hi all, it's apparently clutch time, if no-one buys my car. And I can't for the life of me get my head around which clutch I actually have in the car. The build plate says 4A-GZE and E58-474. It's an 89 model, air-flow meter, DLI, bigport.
    So have I got the 250mm, 253mm, or 225mm clutch? I'm assuming that the smaller clutch was for lowly n/a models, which leaves me with the 250 and 253mm items. Which is close enough to look the same but not close enough to bolt up.
    Any help please?
    I *could* just get the 70% remaining 8-puck clutch I was offered but I think button clutches are about as sensible on the street as a guy in drag. Sure it's funny to watch but you sure wouldn't want it to be you...
    Last edited by BLSTIC; 26-02-2013 at 04:26 PM. Reason: change of title to reflect contents
    May 2012
    Default Re: Identify 4A-GZE clutch without taking gearbox out
    Oh there are two clutches exedy list for the car. The TYK-7411 for 250mm pcd, and the TYK-7501 for 253mm. I can find both online, but don't know which I have
    no, 225mm was a supercharged clutch, it was in the AW11 4AGZE. Lowly N/A models got the 212/215mm clutch
    As for which you have, god would know without pulling it off. at a stab I would guess 225 like the AW11 since yours is still an early GZE, but its only a guess and you should i no way buy one based on that
    edit:
    a quick search saw this http://www.ae86drivingclub.com.au/fo...ctory-flywheel , so if this bloke is correct then an AE92 one is the same as the AW11 item
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    May 2012
    Default Re: 4A-GZE Clutch and flywheel compatibility
    Well I did some more searching and I discovered that if I go by the xtreme website I have
    AW11 MR2 Supercharged KTY23016-1A
    AE92 Levin GT-Z 5/87-9/90 KTY23029-1A 250mm pcd
    AE92 Levin GT-Z 10/90-6/91 KTY23018-1A 253mm pcd
    AE101R Supercharged KTY23017-1A
    Given that I know my vehicle is an 89 model (based on big-port with air-flow meter) I should order the 250mm item. It has a wrecker gearbox (or maybe the gearbox was tagged for wrecking but narrowly avoided it before importing) So that could mean anything...
    But I'll just order the 250mm part and if it doesn't fit, can I get my flywheel modified to suit while it's being machined? Or maybe another flywheel? The price difference is huge between the two clutches (like, $200-300 depending on where you get each one).
    perth
    supercharged flywheel 225mm
    n/a flywheels
    May 2012
    The issue is that there are two supercharged flywheels though The difference being a cool 3mm...
    Thanks for the pics though
    Quote Originally Posted by BLSTIC View Post
    you have there saying 250 and 253mm PCD, that means the mounting points. so technically, [edit] I was thinking it was like the NA flywheel where you could rotate the bolt patterns and redrill, but looking at that pic, no it does not look like you can move the pin locations. So no modifying the flywheel would be out of the question on a budget.
    going off what Nickjoe said on the AE86DC
    nar they are 224/5(aw11-ae92) or 230(ae101). Was measuring up the difference between the ae101 and ae92 4agze flywheels last week, both actually had the same clutch face size however the ae101 had slightly larger bolt pattern/pin location for the pressure plate(probably like 1mm or two difference).
    if your ordering the 250mm item (225plate) i would dare say it would be pretty safe.
    89' MR2 AW11... His
    IMO smartest thing to do is drop the box and measure the clutch plate diameter. you gotta pull it apart to do the job anyways, so why bother waiting to pull it apart and find out you've bought the wrong thing......
    Oct 2009
    Quote Originally Posted by feral4mr2 View Post
    Goes from a single day job into a 2 week job while they get your obscure clutch kit from a warehouse somewhere
    But your right, probably the safest and smartest option if you afford the downtime
    May 2012
    Hmmm... one last question I swear
    What's the spec for the height of the posts that the clutch mounts to? Because if the flywheel surface gets ground and tter posts don't... Less clamping force... I would hardly be surprised if that's what has happened.
    May 2012
    Car is sold. No need to answer, though out of curiosity I'm interested
    Junior Member Conversion King
    May 2010
    Not sure about Yota's, but in regards to other cars I have dealt with (a star badged AWD make in particular), as long as the clutch bolts up to your gearbox, and the flywheel matches the clutch, it shouldn't really matter what diameter either are (within reason though of course, since diameter is related to pressure plate clamp load required etc.)
    So theoretically if you were to find ANY E58/4AG clutch/flywheel combo, it *should* bolt up, unless I am missing something here.
    Anyway, best method I would use is the EPC. Check the part number for the AE92 clutch disk and or flywheel, and find what other models it matches.
    ToyoDIY.com
    PN #31250-17030, OD=224, clutch disk was also used on the GZE MR2
    PN #31210-17020 , clutch cover also used on the GZE MR2
    ToyoDIY.com
    PN #13405-16050, flywheel also used on the GZE MR2
    Your chassis code would have been ACMXR, and provided everything in there was stock, the EPC does not lie about what parts fit in there.
    No idea about post height, but I'd imagine if it being reground affecting the clamping force, then something very wrong is being done during the regrind.
  1. Help identify this clutch pedal and master cylinders
    By illdrift in forum Tech and Conversions
    Last Post: 05-02-2013, 07:00 PM
  2. Help to identify this clutch
    By dori dori in forum Tech and Conversions
    Last Post: 02-04-2011, 01:03 AM
  3. Identify c52 vs c56 gearbox
    By AdrianS in forum Tech and Conversions
    Last Post: 28-04-2010, 04:54 PM
  4. Help me identify my clutch! :)
    By ReQuieM in forum Tech and Conversions
    Last Post: 01-07-2007, 01:42 AM
  5. Identify this Gearbox....
    Last Post: 21-03-2006, 09:32 PM
