Results 1 to 14 of 14
Thread: 3SGE Beams pinging issue
    Feb 2013
    Default 3SGE Beams pinging issue
    Hi Everyone,
    Does anyone know why under light throttle my 3SGE Beams in my Hilux pings its tits off and what can i do to fix it
    I run it on 98 and have also tried 100 octane still does it
    Thanks
    Matt.
    May 2012
    Default Re: 3SGE Beams pinging issue
    Beams motor in a Hilux? Pretty sure they didn't come like that so we need more info.
    Are you running the BEAMS ECU? If not the tune is the likely culprit and it's gonna be pretty hard to diagnose over the internet. In addition to the normal spark and ignition timing these things have variable cam timing, which is cool and all but hard for mere mortals to deal with (and even those with god-like tuning powers if you aren't willing to pay them).
    If you are running the stock computer and the person who did the wiring had half a brain you will still have a check engine light output and a diagnostics plug in the loom somewhere. Diagnosing things via the internet becomes a lot easier when the factory toyota computer can tell us what is wrong with it (and given the correct inputs the stock computer doesn't make mistakes like letting the engine ping).
    Feb 2013
    The engine is stock and running the standard ecu, it has the check engine light (which isnt on) and when scanned using the old 17 pin connector in engine bay and obd2 plug under the dash there are no codes in current or history.
    On a cold morning or when raining it very rarely happens, on a hot day its bad but you can drive around it by changing the throttle percentage. It does have a pod filter in the engine bay (this is temporary)
    Dec 2008
    Wellington, NZ
    Too much ignition advance, inlet air too hot, mixture on the lean side, not enough octane rating, or a combination of these factors. Inlet air temp is obviously having some effect from your comments. Maybe check your ignition timing, and if need be, retard the timing a few degrees and see if it makes a difference.
    Cheers... jondee86
    How much piping have you got between the pod filter (or bend) and the MAF? When Bill Sherwood put a BEAMS in his AE86 he had big problems with turbulence in the intake throwing the MAF off and stuffing up the mixture, he rectified it by basically installing a massive bunch of drinking straws like a honeycomb infront of the sensor to straighten the airflow out
    http://www.billzilla.org/AE863SGE.htm
    Look at the bottom of the page
    Feb 2013
    Thankyou very much everyone,
    i now have some ideas but i think the turbulence mite be my problem
    Here are some pics
    Dec 2008
    Wellington, NZ
    Ahh... something like this.... http://www.saxonpc.com/100mm-cells-for-100.html
    Cheers... jondee86
    May 2012
    That's awesome! I didn't think anyone would market that for modified cars...
    Feb 2013
    I modifyed a vt commodore maf and have driven it for 2 days and still does it, i think i will move the filter out of the engine bay and try again
    Bottled up Domestic Engineer charliechalk's Avatar
    is the idle stable? Cold start right? (1500 down to 1100-1200 down to 750-850)
    checked the throttle position sensor?
    might not be relevant but have you tried reconnecting the cam cover breather hose back into the intake pipe to see if it has an effect?
    Feb 2013
    Yes cold start is perfect as well as the idle
    Throttle position sensor is working perfect
    I'm going to check the timing belt marks to see if it could be out but i somehow doubt it as it runs to smooth apart from the pinging
    oregon
    do you have a vacuum operated fuel pressure regulator?
    Pull the vacuum line from it, plug the vacuum line... KEEP the FPR fitting "open" See if it still does it.
    Feb 2013
    yes i is vacuum opperated, thanks i will give that a try.
    Feb 2013
    Thanks Oldeskewltoy,
    The Hilux seem perfect on the way home today so i will leave it disconnected over the next couple of days and let you know
  1. Replies: 53
    Last Post: 11-04-2008, 05:32 PM
  2. Beams 3sge Rwd
    By gwh1946 in forum Tech and Conversions
    Last Post: 02-12-2006, 08:32 AM
  3. 3sge pinging
    By NeoNasty in forum Tech and Conversions
    Last Post: 21-02-2006, 12:42 PM
