Results 1 to 11 of 11
Thread: a few 2tg & solex questions
    Tasmania
    Default a few 2tg & solex questions
    G'day,
    I am slowly getting my car for rego and i have a few questions (i have done a forum and google search and couldnt find any info)
    My engine is a 2tg with the usual twin solex carbys.
    To pass rego i need to connect the rocker cover breather to the intake, just wondering if there is a normal spot to run this hose? or will i need to rig something up?
    also, i am in the process of building a manometer to balance the carbys, but i dont know where the vacuum hoses connect to?
    any help would be great, thanks heaps
    -Jake
    Nov 2009
    Default Re: a few 2tg & solex questions
    just get a little clamp on air/oil filter like this
    http://web.tradekorea.com/upload_fil...6ac9bc957e.jpg
    Tasmania
    Quote Originally Posted by ctrain View Post
    I can't run one of these, it has to be plumbed back into the intake for rego
    Nov 2011
    You should have two bits on the rocker cover that need to be plumbed into the "Intake" . One is the PCV valve which connects into the same "Bridge" or fitting as the vacuum take off for the brake booster and the other connects to the air filter housing being the intake side of the breather system. It's what's known as a "Positive Crankcase Ventilation system"
    I've never bothered with a "Manometer" to balance or tune multiple carb setups. A bit of garden hose does the job nicely and how to do it it this...
    with the engine warmed up turn it off and wind all the mixture screws in gently until they stop.
    Wind each mixture screw out EXACTLY TWO full turns.
    Disconnect the throttle linkages then start the engine, adjust the idle screws (the ones on the throttle butterfly spindles) until the engine idles a little above spec
    Using a suitable length of garden hose stick one end in your ear and place the other in each barrel of the carbs and listen to the noise that each one makes
    Adjust the idle screws until each barrel makes the same noise and idle is on spec which from memory is around 750rpm +/-50. Then...
    Adjust each mixture screw in or out the exact same number of turns (in 1/4 turn increments) until the engine idles smoothest (this applies if you have stock cams or "Lumpy" cams)
    Re-check that the same noise is heard at each barrel and re adjust if necessary.
    Adjust and refit throttle linkage then re-check the noise if all are even the job done
    If you have one checking the exhaust port temps with an IR thermometer is a good idea, I forget the exact figure but between 160 and 180C springs to mind.
    Hope this helps
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Could you not just run a catch can for the breather hose?
    And 4th surfs guide on tuning carbs is stop on!
    Cam
    SR20DET TA23
    Nov 2011
    Caam sadly not for rego. He can do that later for "Normal and track use" but a point to remember there is no matter what engine if it's an OHC with both the PCV and breather in the rocker cover no matter what condition the engine is in whether new or 700km on the clock it will thru oil out of the breather due to the turbulence created by the cam. so once past rego yes the catch can is a wise idea. In effect that's all about emissions.
    And my tuning guide? My dad taught me the hose bit when I was a kid. Which when I began my apprenticeship as a mechanic did stand me in good stead but the rest was learnt in practice esp being taught by a lot of old school guys. It does help if you have an ear for music or enjoy your music as it is the sound that you need to listen to. I've had a lot of peeps over the years that have told me that I'm one of few mechanics that can tune Carbies by ear. The same rules can be applied to stock EFI, ITB efi and don't ask how but I can do it with diesels too but that also involves looking at the colour of what comes out of the tailpipe, Much like the days of leaded petrol
    The definitve guide for 2T-G Solex tuning....
    http://www.toymods.org.au/forums/tec...rocedures.html
    seeyuzz
    river
    Dec 2009
    Excellent advice - need to hook up my electric fuel pump tomorrow so I can keep mine running so I can tune it, fired it up today with small amount of fuel gravity fed after a long time build up.
    Aug 2012
    Where did you find the 2TG I'm looking for one and thinking I might need to get one from Japan. Any suggestions welcome.
    Jake,
    The 2TG only has one breather on the Rocker cover (no PCV valve on the twin cam)
    From factory this plumbs straight into the back of the factory Airbox. As others have mentioned, an Oil catch can is a good idea after you pass rego.
    For now, See if you can borrow a set of the Ramflow air filters, these has a plastic block off in the base plate designed to take the engine breather. If you buy them new, they will even come with the plastic barb fitting to connect it too. Avoid buying them if you can - They are shithouse filters.
    As for the carb balancing, easiest way to use a mechanical carb balancer is to buy a twin Gauge unit and like this one: LINK
    To connect it you use the fitting location on runner 1 and runner 4 of the intake manifold. You just put a brass 1/8 Barb fitting in for tuning then replace them with ablock off and your Vac feed for the booster when your done.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Apr 2010
    01-02-2013
    SR20DET TA23
  1. Various 1jz questions/master cyl questions
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 30-03-2008, 09:27 PM
  2. 18RG Solex
    By ganador in forum Tech and Conversions
    Last Post: 11-02-2007, 12:29 PM
