Results 1 to 6 of 6
Thread: Bigger AFM options for silvertop 4AGE's?
    Chiba
    Default Bigger AFM options for silvertop 4AGE's?
    Ok, so I hate the AFM on the silvertop engines. I'm not dropping the cash on an aftermarket ECU, as that money is being saved for my Japanese working holiday.
    So, I thought I would look at installing a larger AFM. I have heard that a Gen2 GT4 3SGTE AFM is pretty much a direct replacement, but I can't find any detailed info.
    Has anyone done anything like this, and if so, what's the go?
    I was almost thinking of getting something from a larger engine (supra or the like) and comparing the silvertop readings on a flow bench etc against the replacement and calibrating it to match, but if someone else has worked it out, I won't bother.
    Help?
    Oct 2009
    Default Re: Bigger AFM options for silvertop 4AGE's?
    I cant see it providing an ounce of extra power?
    Why not run it on blacktop electronics, whats a loom, ECU and MAP sensor worth?
    Chiba
    Dunno, but finding them can be a bit of a pain...
    Definitely worthwhile on the 4AGZE's and they had less power than the 20v engines.
    What I did was to use the AFM housing from a 2.2 ltr Mazda 626 and take the circuit board from the original GZE AFM and put it in the bigger Mazda housing. This Mazda housing was the same size as a 3SGTE AFM housing. Something to keep in mind was that the GZE and probably the 3SGTE AFM and 20v 4AGE, used a dropping voltage to show higher load levels.
    Tuning was done via the Jaycar/Silicon Chip Magazine 'Digital Fuel Adjuster' and "No" you can't just fiddle with the AFM flap spring to get it to work well, the behavior is too non-linear for that. End results were good, but I had also fitted a 55mm TB too, so end results couldn't be only a result of the bigger AFM.
    Chiba
    I had a 55mm (3SGTE) throttle body on my MAP 4AGZE and it made a good improvement.
    I *may* have access to a busted E-Manage soon that I *might* be able to fix, but failing that, I want to do what I can with the stock ECU to minimise cost. The damn car has cost me waaayyy too much already, so an after market ECU is out of the budget.
    Oct 2009
    Megasquirt?
  1. Replies: 6
    Last Post: 02-05-2012, 10:16 PM
  2. bigger brakes - bigger smiles
    By Alwaysideways in forum Tech and Conversions
    Last Post: 07-12-2008, 04:29 AM
