Results 1 to 2 of 2
Thread: C50 to C150 Bell housing swap possible?
    Feb 2010
    San Pedro
    Default C50 to C150 Bell housing swap possible?
    Guys!
    I've got a weird problem with my 4AC with a C50 5-speed manual tranny, 2nd gear engages during neutral after replacing the shaft fork. and since i have a spare C150 from a 5-speed 2E 12 valve engine.
    from my point of view they may be the same since they have the same gear ratio's. here"
    C150: 2E 5-speed
    gear ratios:
    1st: 3.545
    2nd: 1.904
    3rd: 1.310
    4th: 0.969
    5th: 0.815
    Reverse: 3.250
    C50: AE82, AE92 (All), AE101 w/ 4A-FE) MR2 Mk1a
    Gear Ratios:
    1st: 3.545
    2nd: 1.904
    3rd: 1.310
    4th: 0.969
    5th: 0.815
    Reverse: 3.250
    final drive: 3.722
    Even so they have different bellhousing, which the starter mount is positioned.
    here:
    2E w/ C150 Tranny
    4AC w/ C50 Tranny
    But then they have the same right side engine/tranny mounts..
    here:
    So my question is, will it be possible that the bell housing from the 4AC C50 Tranny can be interchange into the C150 gearbox without modifications?
    Sep 2009
    Default Re: C50 to C150 Bell housing swap possible?
    They should interchange but you might have some fiddling to do with bearings.
