Results 16 to 28 of 28
Thread: 4AGZE 264 Tomei cams making tapping noise
    Apr 2012
    Default Re: 4AGZE 264 Tomei cams making tapping noise
    i read my Tomei instructions a few times and doesnt specifiy anything other than the normal "check clearences, springs, valves and buckets" etc etc.
    Mine were the same so all clearances were checked & fine.
    They have 8.1mm & heavy duty valve springs so I don't think that's it.
    Thanks for all your advice, hopefully I'll have enough time over the next few weeks to take a look
    Apr 2012
    Quote Originally Posted by oldcorollas View Post
    is oil getting to the head?
    Yeah oils getting to the head
    something dumb like cam caps loose?
    Aug 2009
    Out of curiousity, what are the specs you set it to? I had a problem with hks 272's in 2jz that was loud and ticking, shimmed it tighter and its factory quiet..
    Would be keen to know your specs, we'll know straight away if that's the cause
    Quote Originally Posted by dnegative View Post
    Wade are pretty shit for cam advice, told me the 872a or whatever was fine on stock valvetrain when its not.
    a little off topic sorry but this is not true, I had wade 872A cams on mine with completely stock valve setup. no odd noises or odd wear to speak of. they are the same spec as the pon cams, 8.1mm lift and 267 advertised, but has same actual duration
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    Oct 2009
    Must of been a different profile as the lift was right on the edge of spitting out the shims.
    With the profle of the cam and the lift right on the limit they were not a 'safe street drop in'
    loves hi RPMS Backyard Mechanic
    possibly 8.5mm nick, i know anything above 8mm its required (well really above 9mm lift, 8 to 9mm is a bit of a grey area) so if it was 8.5mm lift it probably would be very close to spitting the shims
    N/A for life...
    Oct 2009
    Yeah was the 1056a (8.58 lift) profile, nobody I asked aside from Wade would recommend them on stock valvetrain.
    Aug 2009
    Still waiting to hear what the clearances are..?
    Apr 2012
    Im not sure on the clearances but I've had two different workshops look at it & they both said everything is within the standard tolerances, I even had TERRA come over & he checked it out. I read somewhere else on here that someone had a similar problem & all it was, was the gasket on the exhaust manifold.
    I have a video of what it sounds here.
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Is your cam-belt tension o.k? (not too loose)
    == 4AGZE SC14 Supercharged ==
    Junior Member Grease Monkey Jaffa's Avatar
    If all the clearances are ok and oiling is not an issue check the collets and retainers? If you have new collets and retainers it could be as simple as the angles are slightly miss matched and they never seat properly to each other, it sounds just like your vid, this rattle will go away once revs are onboard, its not a good scenario as eventually the collets will pull through from wear and drop the valve.
    Regards
    Jaffa
    Apr 2012
    Thanks for all your responses guys. I finally got it back after getting it looked at, a couple of the clearances were slightly out so I got it all shimmed & now its much better & has eliminated most of the tapping noise. Now it seems one of the buckets is making a noise but hey I can live with that.
    Thanks again for everyones input.
  1. 1JZGTE hollow tapping noise
    By JZA70R_92 in forum Tech and Conversions
    Last Post: 23-07-2013, 12:40 AM
  2. 4agte tapping noise when idling
    By Necros in forum Tech and Conversions
    Last Post: 22-02-2007, 10:06 PM
  3. Tapping engine noise under load
    By Tom86 in forum Tech and Conversions
    Last Post: 30-12-2006, 01:47 PM
  4. 7A engine making loud tapping sound
    By 86_celica_3sge in forum Tech and Conversions
    Last Post: 31-08-2006, 04:51 PM
