Results 1 to 15 of 20
Thread: 18rgue need help
    Oct 2012
    Default 18rgue need help
    Hi , i have a 18rgue that im rebuilding , looking at a new set of rings , the pistons that i have i thought were standard as the bore size i have is 88.5mm , the problem that i have is the 2 top compression rings for the pistons i have are 1.5 thick , when ordering rings they are saying the standard rings for that motor is 2mm top ring 2.5 second ring , can anybody help me sort this problem out as i want to use the original pistons that i have. The pistons that i have are a dome top and im using carbies instead of fuel injection.
    Aug 2009
    Default Re: 18rgue need help
    It seems you may have some aftermarket pistons and depending on the size of the dome, you may have high compression ratio forged ones. Put some pics up if you can
    Are there any brand/markings inside the pistons? If you can find this out, you can buy or get made the ones you need. Have a look in the ARIAS site for a reference
    http://arias-pistons.myshopify.com/collections/rings
    Rgds, Willofan
    Oct 2012
    They have the toyota symbol on the inside with code number 88270 and they are a dome top
    I am fairly certain that the later model 18rgeu, has thinner rings than the 18rg and that the rings that you are trying to order are for the 18rg that had thicker rings.
    Cheers Dave
    1977 RA28
    1972 TA22
    1984 Supra
    Sydney N.S.W
    I had the same problem. Rings being thinner. I overcame this by getting the pistons machined to suit a std thickness. Works fine. 18geu pistons do have a slight dome, from what I remember on mine. But they are still 8.3 comp give or take.....
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Did you have any luck finding rings for your eu I discovered the same prob a while back and haven't overcome it yet
    Oct 2010
    I am also going through this. I have 2 18rg's with late 18rgeu blocks, both have 88270 pistons with 1.5 top and 1.5 midle rings.
    Would like total seal rings. Mine are also standard 88.5m bore. Just gave a quick hone.
    Where to find!!!!!
    1983 Toyota Corona RT133 XX
    W50, 18RG Twin 40 Solex
    Feb 2012
    Sa
    Shop High Performance Piston Rings Online - Deves.com lists them at 1.5mm thick @ 92mm diameter not sure if these are the standard size or not
    Oct 2010
    Pretty sure that is over sized
    Feb 2012
    Sa
    I thought it might be but as I couldn't find ring diameter specs anywhere I thought I'd post and hope
    Oct 2010
    88.5m is standard bore off the top of my head
    Feb 2012
    Sa
    Oct 2010
    hmmmm... Wonder what they are made of
    Feb 2012
    Sa
    Shit but its not like the eu has high compression
    Feb 2012
    Sa
