Results 1 to 2 of 2
Thread: mx83 pin outs
    May 2012
    Default mx83 pin outs
    hi all ive been searching for hours and hours and still found nothing, after a wiring diagram for a mx83 cressida series 1 ive found links but they dont seem to be working
    im trying to wire up a jzz30 into my x83 ive found pinouts for the jzz30 but cant find anything for the x83 found heaps of us model stuff witch is heaps different
    help would be appreciated cheers Bevin
    daily/tourer : gu patrol boosted dented etc
    slider: x81 markii 1uz single turbo caged e85 etcc
    cruiser: x73 2jzge w58 steelies
    Default Re: mx83 pin outs
    this mght help
    copied from a previous post
    Here are the colours of the wires and their functions on my MX83 GRANDE loom plugs from 7MGE motor to underdash plugs
    White plug
    yellow with brown spots___________ speedo speed sensor
    brown _________________________ speedo speed sensor [make sure you earth this one]
    yellow_________________________ temp sensor
    black__________________________ tacho
    yellow/blue _____________________ oil pressure switch
    red/green [2] __________________ reverse
    green__________________________ park
    red ___________________________ neutral
    blue___________________________ drive
    light green______________________ 2
    pink __________________________ L
    Square grey plug
    small black/white _______________ AC clutch
    blue/red_______________________ FP diags
    black/red _____________________ +B diags
    red/black _____________________ 12v supply for speed sensor etc
    big black______________________ nsw
    big black/white _______________ nsw from start relay
    light green ____________________ goes to purple/white in other grey plug
    green with spots _______________ tccs diode
    green/white ___________________ stop light switch
    big black/yellow________________ power from ignition
    small black/yellow _____________ solenoid 2 in transmission to cruise control ecu
    green________________________ from airflow for circuit opening relay
    black _______________________ from temp sensor on water inlet to start injector
    Rectangular grey plug
    pink__________ _______________ TE1 diags
    brown/black __________________ earth
    pink/green__________ _________ TE2 diags
    grey________________________ VF1 diags
    purple/white__________________ goes to pink. and light green in other grey plug
    grey/green___________________ brown wire on abs sensor
    pink/blue ____________________ grey wire on abs sensor
    purple ______________________ blue wire on abs sensor
    Jealousy is a curse
  1. JZA80 ecu pin outs
    By coronaowner in forum Tech and Conversions
    Last Post: 28-09-2009, 06:20 PM
  2. 7m-gte ecu pin outs diagram.
    By moz rolla in forum Engine & Driveline Conversions
    Last Post: 08-04-2007, 01:03 PM
  3. mx83 7m pin outs.
    By nb86 in forum Tech and Conversions
    Last Post: 30-01-2007, 01:25 PM
  4. alternator pin outs
    Last Post: 11-12-2006, 09:37 PM
