Results 16 to 30 of 53
Thread: 1UZ Conversion Power Issues
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: 1UZ Conversion Power Issues
    If you are getting an error code 12, try this troubleshooting procedure - it's for a 91 SC400 but should be pretty universal across all 1UZs of similar age
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Nov 2011
    Try another ecu maybe
    Or bring car up here and ill look at it hehe
    Feb 2012
    Quote Originally Posted by dumbass View Post
    i could try another ECU - if i can find one!
    QLD is a bit far to drive it in base map. haha
    “Speed has never killed anyone, suddenly becoming stationary... that’s what gets you.”
    Jeremy Clarkson
    vic
    maybe the crank or cam sensor wires have been reversed , sometimes the wires pull out of the plugs when the plugs are brittle and have been put back in wrong.
    Dave
    Nov 2007
    I know you're busy tracking a fault, but when you get it sorted could you start a build thread for this. I'd love to see some pics. Always thought it would be cool to own a 4 runner or surf with a 1uz. Alas i don't have the time nor money to take on such a task and have to live through others joy.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    i was dead set worn out when we were looking at wiring, the power wire for the left camshaft sensor was open circuit between the ecu and sensor.
    i think it was also sorted to ground.
    i beleave the issue lies there, will just need to get time to head back out and check it out.
    http://www.toymods.org.au/forums/showthread.php?t=74911
    above is the build thread, though its now lacking updates
    im sure one of use will keep you posted
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    one think im unsure of is if i run a new Unsheilded wire for the camshaft position sensor will it still work?
    i cant remember if the sheilding is to keep elec noise in or out?
    dan.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    Nov 2011
    He's tot use shielded cable
    But if u plan to run a whole new shielded cable from sensor to ecu its big job
    Once u split a loom apart its never the same. And will look messy as all fk
    Have u put timing light on it
    Should be bout 12 degrees then climb as u rev it
    Send us the loom and ill wire it properly hehehe
    Feb 2012
    Yeah used a timing light. Timing is around 4 degrees at idle and has no advance. Only retards when revved/driven has no advance what so ever.
    Will u do it for free?
    Are there any sensors/signals that would cause this that we may not have wired in?
    Jeremy Clarkson
    May 2010
    Moscow
    Send him $500 as a gift and he'll do it for free %)
    SPANNER CRAB Grease Monkey AE3SGTE's Avatar
    Jul 2007
    If you think its your wiring, I am using this guide to wire mine, might be worth a look. Its very good.
    http://oldschool.co.nz/2011/forum/in...=30736#p701443
    Nov 2011
    500 bucks. I dont get out of bed for less than 1000 hehehe
    It's easy to wire them up
    It's very hard to learn how to diagnose
    If timing ain't advancing then its in limp mode
    Wire in a diagnostic plug and plug a scanner into it
    It might give u something else
    But I recon u need to get rid of your code 12
    So it's either a sensor or ecu or wiring
    wiring to both cam and crank sensors is fine
    no high resistance, no shorts to ground, no shorts to positive
    pins and connectors are all good fit
    be great if i had a ociliscope to check the signal from the sensors.
    code 12 cant be cleared, ATM im thinking that the ecu may have an internal fault.
    pulled it apart, visually it looks fine.
    nathan payed for one today as it came with the missing body plug we need anyway.
    will see how it goes.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    May 2010
    Moscow
    make sure STA pin is NOT receiving +12v when driving, feel free to send some beer if that helps )
    driving or running?
    nath can send beers.......his car haha
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
  1. Maf Conversion Issues
    By TOTGAS in forum Tech and Conversions
    Last Post: 22-02-2011, 03:34 AM
  2. power issues, alternaator?
    By ecko in forum Tech and Conversions
    Last Post: 10-09-2010, 11:25 AM
  3. AW11 Wiring issues after conversion
    By trdee in forum Tech and Conversions
    Last Post: 03-08-2009, 04:32 PM
  4. 2tg conversion issues
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 22-06-2009, 07:27 PM
  5. ma70 7m power issues
    By big_fella in forum Tech and Conversions
    Last Post: 23-12-2007, 11:15 AM
