Results 31 to 45 of 53
Thread: 1UZ Conversion Power Issues
    May 2010
    Moscow
    Default Re: 1UZ Conversion Power Issues
    best if you check both driving and running...
    Nov 2011
    Check the fuel pressure and flow. sounds like you may have the fuel hoses back to front
    His. 2005 GRJ120 Prado VX
    Junior Member Domestic Engineer Hurricane's Avatar
    lack of timing is 100% the current issue ATM.
    dont have a fuel pressure gauge to use ether, but i would like to get one on there to check it any way after we sort out the timeing issue
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    May 2010
    Moscow
    Fixed or gave up?
    Feb 2012
    Ill never give up. Getting some help at the moment ill update when I get it fixed
    May 2010
    Moscow
    ok, so it wasn't what I supposed?
    ive not been back to check for the voltage at STA pin, not sure nath has ether.
    nath did get the ecu checked by Injectronics and was told it was failty and payed for it to be fixed.
    im sure he said that he put the Fixed ECU in the car and Code 12 is still preasant along with a major lack of power.
    dan.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
  8. #38
    Nov 2011
    I just fixed a 1uz which someone else tried to wire up
    500 bucks and a day later its all sorted
    Personally there is no fking way the shops who repair ecus can test them 100%
    So I think half the time it's a waste of money just like it happened here
    The problem is still there
    Sta pin I think only gives it fuel enrichment
    Not sure if it retards timing when cranking
    But stop chasing other shit
    Until u fix code 12 don't worry bout anything else
    Code 12 is something to do with timing
    Your timing is at 4 degrees. Should be 12
    So its not rocket science
    I doubt its fuel
    U need to fix code 12 before I look elsewhere I think
    It must be in limp mode
    Have u seen this motor run ok like maybe in a front cut
    Was it a complete setup
    The one I fixed yesterday got a front cut but had air flow plug cut off
    Stupid shit like this have the customer many headaches and expenses
    All because the importers who sold the motor to him had cut the air flow meter plug
    Mind u it was also wired up a little bit wrong
  9. #39
    Nov 2011
    One other thing
    Did he mention to injectronics about code 12
    And what did they fix on the ecu. Just the normal bad caps?
    Ecu repairs is the biggest fking scam
    There is no way they could bench test for code 12
    Half these fking ecu repairers don't even have diagrams for most of these ecus
    I know because I always being asked for some
  10. #40
    i think that we are all on the same page in saying that fixing code 12 is the issue for lack of timing. as its relating to cam or crank angle sensors
    the issue we are having is fixing that code, following the factory diagnousis steps we ending up at replacing the ecu.
    so next step was to get it tested, were told it was failty and i beleave they said it was likely to cause issues with timing and they had seen it before.
    goin with that info there was no point saying know.
    i beleave nath is talking to somone atm that is helping him out?
    im waiting to here how he goes there before i go back and look over the wiring relating to code 12 again.
    motor was bought on its own, came on a pallet, so nether of use have seen it run before being coverted into naths car.
    im not sure on the full details of what was done to the ecu, nath will have to fill us all in.
    dan.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
  11. #41
    Nov 2011
    U really need to get a good ecu or check your ecu in a good running car
    What is the ecu again. What plugs
    I have 2 1uz ecus
    One is early Celsior
    Other is 1996 Celsior
  12. #42
    Jan 2013
    I've worked on Toyotas but I've never touched a 1uz so i do not know how to set the base timing. is it possible for the ignition base timing to be off?
  13. #43
    Nov 2011
    Ecu is in limp mode so it retards timing
    Should be 12 at idle then go up as u rev it
    Sounds like this one is staying at 4
  14. #44
    Jan 2013
    Quote Originally Posted by George View Post
    make sure STA pin is NOT receiving +12v when driving, feel free to send some beer if that helps )
    I agree with George here. the ECU will not advance timing if it "thinks" the starter is still engaged. so any RPM above cranking speed throws a code 12.
  15. #45
    Nov 2011
    Just cut both nsw and sta wires that will tell u 100% if that's the problem
    U are having intermittent problems so I'm guessing ecu
    Anyway u could always wire in a diagnostic plug and see what data u get out of it
    I'm waiting for plane to arrive to fly to Sydney to wire up a car
    Maybe I should take a detour to melb heheeh
  1. Maf Conversion Issues
    By TOTGAS in forum Tech and Conversions
    Last Post: 22-02-2011, 03:34 AM
  2. power issues, alternaator?
    By ecko in forum Tech and Conversions
    Last Post: 10-09-2010, 11:25 AM
  3. AW11 Wiring issues after conversion
    By trdee in forum Tech and Conversions
    Last Post: 03-08-2009, 04:32 PM
  4. 2tg conversion issues
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 22-06-2009, 07:27 PM
  5. ma70 7m power issues
    By big_fella in forum Tech and Conversions
    Last Post: 23-12-2007, 11:15 AM
