Does it misfire under load or at idle?. Like you said replace the coil and any other cheap disposable component (rotor button, dizzy cap, condensor) so as to rule out any faults from that side of things. Then get it tuned. Any reputable tuner should be able to find and sort out the misfire. Has the motor had any work done to it or is it just standard?
