You said you had just put a new motor in, are you sure it was the same type of motor? It's possible you may be running the 1.3L motor on the 1.5L ECU by mistake, or vice versa. Check everything over again, all of your wiring and connections, pipework etc, check you haven't left anything out in the engine swap. Especially if it was a secondhand motor, best to pull the plugs out and check them, test the coilpacks and check out the airflow meter/MAP sensor. Start there and let us know how you go.
