Results 1 to 9 of 9
Thread: ECU daughterboards - other than techtom
    May 2011
    Default ECU daughterboards - other than techtom
    hi all,
    has anyone heard of ecu daughter boards for 4age bigport other than the techtom?
    cheers,
    adam
    Aug 2012
    Default Re: ECU daughterboards - other than techtom
    ECU Daughterboards Australia
    There is a lot of info here…
    forum.pulsar.org.au/archive/index.php/t-75281.html
    Cannot post a competing forum URL cnp the text into your browser to open…
    You may find what you want in all that info…
    May 2011
    hi Demasi,
    thanks for the link, looking for a toyota specific board, i would really like to retain stock ecu but be able to play with the parameters
    Nov 2011
    There's not much if any stuff for Toyota ecus
    No one has really spent time to crack the Toyota ecus
    Someone has don't something with the 1uz soarer ecu I think
    It even those are limited
    Don't waste your time and go aftermarket
    What do techtom do
    I know they make a plug in data box so u can read live data
    Didn't know they do boards
    Chiba
    There was some real headway being made on a UK MR2 forum a few years back. They had daughter boards being made and all for the SW20 MR2's IIRC, wouldn't be a stretch to fit one to a 4AGE.
    Nov 2011
    It depends
    The ecus could be totally different inside
    U look at the nistune stuff
    All the Nissan ecus look the same from outside
    But there is 4 or 5 different types of boards
    It's pretty complicated stuff otherwise it would have been done by now
    Also the demand isn't there world wide
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Hi, is the big port the yellow or grey plug ECU ?
    Quote Originally Posted by dumbass View Post
    It depends
    Years ago there probably would have been a market for it, but now, probably not. Also, the vane/flap AFMs are a pain in the ass.
    The earlier computers seam to be pretty simplistic, too.
    When I was mucking around with a bigger AFM on my SC AW11, I found that at full throttle, changing the AFM signal had no effect on AFRs. But the AFM definitely had an effect on low load AFRs and also the switch on point for the SC. So that had me wondering about how the Toyota ECU's go about their load sensing for the fuel and ignition maps.
    For newer than the AW11 era cars I'd guess the ECU were more capable (shit, the '88 4AGZEs still had a cold start injector ) and they'd be more worth while to develop daughter boards for.
    The following thread has some info...
    http://www.supramania.com/forums/sho...embly-Analysis
    Wilbo's JZA80
    Wilbo's JZZ12
