Results 1 to 11 of 11
Thread: 4AGZE Harmonic balancer
    Dec 2008
    Question 4AGZE Harmonic balancer
    I've currently got a 4 AGZE in my datto 1200 ute but don't need the front pully and could use the room for my thermo fans. Was just wondering if they make a aftermarket balancer without the front pulley
    Cheers Mick
    2SCARY JZA80 back yard built makin 888.8 rwhp 1360 nm torque
    GET UP A Datto 1200 ute 4AGTE W50 celica box hilux diff also back yard built power unknown so far as its still being built
    Jul 2007
    Default Re: 4AGZE Harmonic balancer
    try technotoytuning. they do aftermarket pulleys for the 4A
    Dec 2008
    Wellington, NZ
    Asfarasiknose, you can part off the front pulley, and use the rear pulley on its own. The rubber insert is inside the rear pulley, so it still acts as a balancer.
    Cheers... jondee86
    Dec 2008
    Cheers jondee I actually did exactly what you said only a couple of days ago I'll continue to look for and aftermarket one that rubber danpned as I got I contact with technotoytuning but there's isn't rubber dampened
    Mick
    Junior Member Grease Monkey rick q's Avatar
    I turned the front part of the original pulley off mine [Silvertop] about 5 months ago and it's seen lots of track days since then without issue.
    It's a casting, by the way, so you'd be better off with carbide lathe tools to do the job.
    Cheers ..... Rick Jones
    Fraser Clubman
    Dec 2008
    Cheers rick q hopefully mine will hold up too
    Also what do you rev yours too ?
    Mar 2011
    plenty of people run cut down crank pulleys on their 4age's
    SHEPPO..
    Apr 2007
    Do they run a proper harmonic balancer on the 4agze motors, years ago most 4cyl motors of different manufacturers didnt run a dampened pulley due to the short length of the cranks, etc they didnt seem to find it necessary ..
    It makes peak power at 7,700 - so I don't take it muck over that [limiter set to 7,900]
    Fraser Clubman
    S.A
    I also parted the front off of mine no dramas to 9500. Have been debating if i should go to a solid style pulley on the front for a while now..... alot of people seem to be using them with no issues reported that i have found.
    Im looking to switch to crank angle sensor on next motor and the t3 ones are ready made and would just make thigs a bit easier. Just not sure on the whole no rubber dapen issue.....
    Anyone run them..... anyone know of any issues ????????
    perth
    ive also turned down my 4age one, to run a crank angle sensor on it. no issues either.
    http://rossperformanceparts.com/meta...balancers.html
    i priced one up years ago for my 4age. custom with degree marks all way around it (for dialing in cams) and provisions for CAS. they came back with a price of 600$+. at the time, i thought the stock one was pretty good and been running that ever since haha.
    didnt the solid 4agze crank pulleys used to always crack ?
