Results 1 to 8 of 8
Thread: Per Eckland TRD Group A cam specs
    Melbourne Victoria
    Default Per Eckland TRD Group A cam specs
    did these 10 years ago and have just found the paper work for these /will suit 2tg or 18rg
    400 thou lift
    338 at 6 thou
    50 thou 254.5
    lobe centers are 105
    on my other 2tg TRD cam grinds the 304 and the 288 profile this cam is higher than the 288 trd profile
    Default Re: Per Eckland TRD Group A cam specs
    For those not aware of your engine project(s)... what engine and specs are we talking about here?
    Melbourne Victoria
    read it again as it says 2tg and 18rg
    So you did, sorry
    Feb 2012
    Aberdeenshire
    hi RA45.......as you know from another thread I have these in my 2t/3t hybrid.
    As I am not familiar with cam profiles and specs where would you say these cams sit? Very mild.....mild..warm....getting warmer?!!
    In the 1600 they were cammy but in the 1940 they only have a mild lift at 4,500rpm but they do pull really well from about 2,500 upwards....loads of torque.
    Part of the reason for asking is that at some point I might want to get hotter cams and it would give me some kind of reference as to what I actually have.
    Many thanks for your help!
    Brian
    Melbourne Victoria
    these are hotter than the 288 trd profile
    and i work on 50 thou duration to tell me how hot these are
    anything past 260 at 50 is getting up there 3/4 race cam
    so in your case 245 to 260 is where you need to be around and maybe use a bit of lift as well
    VAASA / FINLAND
    Per Eklund cams made from like these ?
    http://lelu.wb-clans.com/trd/IMG_1227.JPG
    I know that some factory race teams grind their own race cams. (small cheating)
    some class Rules says stock cam & timing, or used camshaft had to be homolocated.
    But they grind camshafts inside homolocation specs, Opening time, Closing time & Lift, so "Stock" cams are not stock, just measured specs are inside homolocation, and core is same than stock ones got. So no one can say nothing.... just profile is different. open & close faster.
    - Celica TA-22 -74 2T-G Turbo
    - IQ 1.0 -09
    - Lexus IS250 -06
    Feb 2012
    Aberdeenshire
    Quote Originally Posted by Celica RA45 View Post
    Thanks for your reply! It gives me an idea of where I am and where I might need to go.
  1. 7M-GE Specs
    By SLO-030 in forum Tech and Conversions
    Last Post: 20-03-2009, 02:15 PM
  2. Turbo Help Pls On Specs
    By The Count in forum Tech and Conversions
    Last Post: 27-07-2008, 10:45 PM
  3. 3tgte cam specs
    By metcap in forum Tech and Conversions
    Last Post: 22-02-2008, 09:43 AM
