Results 1 to 15 of 19
Thread: What is this sensor for?
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Default What is this sensor for?
    After inspecting my rear spark plugs with the intake off, i found this little connection in the intake manifold. It has 1 wire, a brown one, with a blue connector. To me, it looks like a temprature switch, but why would this need ANOTHER one? Theres already 4 of them that i know of dotted around the engine already...ECT Sensor, CSI Sensor, Fan Switch and a Guage sensor.
    What is this one for!
    Pics:
    A better pic of the actual sensor and location.
    Thanks!
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Default Re: What is this sensor for?
    That is your gauge sensor.
    Although the brown wire suggests otherwise, the sensor it plugs in to is definitely a guage sensor.
    water temp sensor for you dash
    yep, water temp, usually independent of any efi sensors too
    Hmm i see!..so that makes me wonder then, what the other two connections are on the upper and lower radiator housings. The bottom one is a single wire, and the top one is a 2-wire. Fans i guess then?
    Kind Regards,
    Kurt.
    Quote Originally Posted by JetspeedCamry
    the single wire one directly above it with the round plug is your thermofan sensor plug...
    Quote Originally Posted by Robbos_Toyotas
    Ah ok..thats on the top housing. Theres also one on the bottom thermostat housing, round plug..but 1 wire. Any idea?
    Kind Regards,
    Kurt.
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    What colour is the wire? Most prob from what everyone is saying it's a tempreture wire, but your car was auto, so it could be something to do with the Auto temp senor. The trusty old SA63 had two sensors, one for the temp guage and we are lead to believe the other one is for the auto transmission... It's still there to this day...
    Can't afford it?... Don't buy/drive it...
    James (Viper_Nipplex), We will miss you - Rest In Peace - 11 March 2009
    Its a brown wire, with a blue connector. If it was something to do with the ECT ECU, what would it be for?
    This is the other one im talking about on the thermostat housing at the bottom of the motor...
    So if that little one is for the guage, the top one if for the thermo fans...then what is this one?!!! (something for the ECT ECU? Torque converter lockup?)
    Last edited by JetspeedCamry; 31-05-2006 at 05:57 PM. Reason: Added pic and other question
    Kind Regards,
    Kurt.
    the engine ECU also needs to know the coolant temp - ECT ECU's usually get temp sensor data from the engine ECU.
    cheers,
    Charles.
    cheers,
    Charles.
    Yeah, that sensor is on the coolant bypass pipe, along with the CS time switch and BVSV's.
    Any idea what this one is, on the thermo housing?
    Kind Regards,
    Kurt.
    could be AC or climate control. some wont do certain stuff until motor is warmed up of until the coolant is above a certain temp.
    Unplug it and see what code the ECU throws
    244rwkw / 328hp @ 18psi
    cold idle sensor for the ecu??
    VZ engine series FTW! Grease Monkey Timma's Avatar
    May 2006
    i thought it was the temp sensor... mmm another thing to look @ on sat
    vzv21 camry 2vzfe v6 - aka mr burble or white one
