Results 16 to 17 of 17
Thread: Opinions on 4AGTE combo
    Oct 2012
    Default Re: Opinions on 4AGTE combo
    Quote Originally Posted by oldeskewltoy View Post
    I'd recommend the later version of the rods and pistons. The rods... you are saving 15+ grams of mass... the pistons having higher compression allows you a bit more freedom with combustion chamber shape(removing material from the chamber to allow a superior burn)
    You are NOT going to be making 500hp without SERIOUS headwork. At the BARE minimum you will need a careful deshrouding, and reworking of the exhaust ports. I'd recommend different cams too (more lift), I'd also recommend O/S valve as well
    I've already decided to use the later GZE rods and pistons with 8.9:1 compression. I've also changed to a Kelford Turbo Cam as it better suits the combo and has better lift and duration than the HKS cams that I listed, as well as possibly oversized valves. I'm not interested in making 500hp, 250hp at most because it will mostly be street and some track occasionally.
    Would you say it's worth going with the oversized valves? I don't know of anyone who has results comparing the difference.
    Low rep 1st year Apprentice
    Aug 2010
    Have you thought about a COP option instead of MSD with leads?
  1. 4AGTE & Disco Potato Opinions
    By dave_101 in forum Tech and Conversions
    Last Post: 28-03-2011, 02:08 PM
  2. the right combo for my 1jz 4bie?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 12-11-2010, 09:36 PM
  3. Engine combo
    By Blade20034 in forum Tech and Conversions
    Last Post: 10-07-2006, 05:01 PM
