Results 16 to 27 of 27
Thread: 1uz aftermarket ignition ecu?
    Nov 2011
    Default Re: 1uz aftermarket ignition ecu?
    I have been considering one of these for mine
    http://www.spitronics.co.za/cms/enginemanagement.php
    Cost of around $450 plus postage and a few peeps in Perth run them on both petrol/gas and dedicated gas. I've not heard anything bad and it does come with everything needed as I've had a few chats to the supplier. However my plans have changed after miss 16 stole my wifes 2.4TD Surf and killed it. So a UZ with auto is going in hers and I'll be selling mine and keeping the 2door for myself and get the wife a "Playdough"
    His. 2005 GRJ120 Prado VX
    Feb 2011
    sa
    Wow this looks like just the thing for now, seems to have that 36-1 wheel I was asking about I will contact spitronics and see what they can do, what with loom and all it sure seems the go. Thanks to 4th Surf and Mr D (cant bring myself to call someone dumbass who is helpful)
    Rob
    Nov 2011
    hehe u can call me dumbass i wont cry
    i think i lost a bet awhile ago
    ive got a td cortina show car to do soon with morrison xram manifold should be fun
    Feb 2011
    sa
    Update - got my Spitronics gear from Sarth Efrika today. Looks like even i can fit it, went to u pull it and scored two coil plugs and waiting for new plug for the crank sensor to turn up already ot new inj plugs. Spitronics supplied a new 36-1 wheel; looms for power,injectors,idle and sensors, has coil igniter built in and is about as big as a digital camera! They supply a tuning disc and the ecu is programmed with a start up map, speaking of maps i got a MAP sensor to swap out the Karman Vortex VAF All for less than $500. Once i get organised i will take a few progress pics.
    Rob
    Nov 2011
    Pity they can't use the factory trigger setup
    If u blow up a motor means pulling it apart
    But I guess for 500 bucks its ok
    Are u running an auto box
    As u ll need something to control it
    Feb 2011
    sa
    Auto box - I got a manual shift controller from MV Automatics here in Adelaide, 3 on the floor with a Hurst pro stick bang shifter and OD and convertor lock via switches. Should be gangs of fun! And hey if I blow it up Im gonna be pulling it to bits anyway.
    Rob
    Sep 2010
    Hey Rob,
    Have u fitted the spitronics yet?
    I've sent them a couple of emails with no response.
    Im also keen to jump aboard to try this out.
    Feb 2011
    sa
    Well I got the Spitronics setup, the package from South Africa included one ecu one idle control ecu, EFI loom, MAP loom, power relays, ignition loom and a couple more looms for lamda and crank with the 36-1 wheel; also a disc for laptop tuning and it came with a startup map. Next I spent a few weeks relearning how to solder and run wiring. last thursday I plugged in the laptop and found out you needed to install a driver for it to work. Install a driver! I thought that was me... OK all the sensors were sensing and I had power to injectors, coils, fuel pump and idle stepper motor but after several attempts still no go. I went back to the manual - and found out the ECU was not getting powered up so after a little diagnosing I found a bad connection to the fuse box. Now check the fuel pump and try again. NO exhaust so I figured this would be a short run, Carolyn came out after it fired up - after ten years sitting idle it fired up after two turns on a couple of injectors then a couple more. Stopped it and walked around looking for oil leaks etc; fired up again and started sounding less like a lawn mower and more like a car. Three more injectors woke from their slumber and then they all worked woo hoo. I have yet to tune it but ill wait till after the headers and exhaust are done. Next job wire up the manual shift box from MV get a tailshaft and i think finishing the brakes could be a good idea. Its geting there!
    Based on how she started up, I'd take the injectors out and get them cleaned professionally.
    Sep 2010
    good work mate
    Nov 2011
    50 % of import motors have sticky injectors
    its not that they r dirty its just the fuel sticks em shut
    the heat makes them come good sometimes
    and ive never had to tell customers to get them cleaned
    plus the 1uzs run so good i did get my inectors cleaned after 200 thou kms on motor and
    before and after specs were the same
    but in the end it is best to get the cleaned
    The first 1UZ I had was running lean enough to have the exhaust glowing.
    Had the injectors cleaned and it went back to running properly.
  1. Ignition coils - aftermarket - which one?
    By mike1980ra40 in forum Tech and Conversions
    Last Post: 04-09-2008, 09:35 PM
  2. 20v ignition
    By greenmac80 in forum Tech and Conversions
    Last Post: 18-08-2008, 11:51 AM
  3. aftermarket ignition coils?
    By benny c in forum Tech and Conversions
    Last Post: 28-10-2007, 09:08 PM
  4. Replies: 5
    Last Post: 21-12-2006, 09:46 AM
