Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: JZX110 into MX83 Help Please
    Default Re: JZX110 into MX83 Help Please
    89661-3a680
    Jealousy is a curse
    Aug 2015
    berbice
    Quote Originally Posted by madmont View Post
    89661-3a680
    that ecu # is from a 1jzge engine (non turbo) see below
    Part 89661-3A680 (COMPUTER, ENGINE CONTROL) was found on the following models:
    Market Date range Model Frames/Options Found in diagram
    Japan 09/1999-05/2007 TOYOTA CROWN, CROWN MAJESTA GS171,JKS175,JZS17*,UZS17* 84-04: ELECTRONIC FUEL INJECTION SYSTEM
    Model Dates: Matching Models: Model Options: Links to diagrams:
    09/1999-07/2001 JZS171-AEPQF ROY, JPN, SED, 1JZGE, TWC, ATM, 4FC 84-04
    09/1999-07/2001 JZS171-AEPSF ROYEX, JPN, SED, 1JZGE, TWC, ATM, 4FC 84-04
    Correct ,...........
    Aug 2015
    berbice
    how can i get info for the jzs171 ECU #89661-3A870
    Quote Originally Posted by hititup View Post
    Some drawings from madmont on my wiki <here>
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2015
    berbice
    Quote Originally Posted by wilbo666 View Post
    Thanks.. i mite have to call in a pro to piggyback my IS200 ECU to run the car and leave the JZS171 ECU to run the engine. This was the 1st swap i wire up and dont know nothing about running a piggyback.
    Aug 2015
    berbice
    Quote Originally Posted by George View Post
    JZS171 / JZX110 digital commands (MPX) are not compatible
    However I have a hardware solution for that
    what is the hardware solution? i need it real bad.
  8. #38
    May 2010
    Moscow
    Analog to MPX converter
    Currently supported are JZX110, JZS/UZS17x, JCG11x, UCF2x, UCF3x, JZS16x
    Each chassis has its own encoding scheme
    A converter can command engine control unit to activate particular mode
    Standard set of modes are ECT power/snow, A/C on/off, ELS (idle up for electrical load)
    Such a command is sent to ECU via MPX
    Each command is activated by appropriate control wire of the converter (connect wire to ground-activate its mode)
  9. #39
    That sounds pretty interesting. Wonder whether it would be something that would help override the cruise control limiter on my Crown?
  10. #40
    May 2010
    Moscow
    It has nothing to do with cruise control. Not even remotely. Cruise control is activated by just one wire from ECU to earth
  11. #41
    My understanding was that the cruise ECU picked up speed signal from the speed sensor on the output shaft of the gearbox via the multiplex and then issued commands to the throttle. I was hoping that if an analog-to-MPX converter existed, an MPX-to-analog converter might too. Sorry for the off topic.
  12. #42
    The JZS171 has a speed sensor on the transmission which is used for automatic transmission ecu and cruise control.
    I have a JZS161 motor fitted to a manual gearbox . I fitted a rotor to the output shaft to give me a speed signal for the cruise control. It now sends 10 pulses per revolution instead of 12 which enables the cruise control to go to a higher speed and raises the vehicle top speed limitation as well. The cruise control works well and I am not about to test the top speed anytime soon.
    Jealousy is a curse
  13. #43
    Aug 2015
    berbice
    Sorry to go off topic but i dont know where to put this. my mate doing a 2JZGE swap to his Altezza, 1GFE and he ask me to do the wiring. i get the engine to run But i cant get the speedo to read and his ABS light is on. I just dont know where to get the speed signal from the jzs161 ECU #89661-3A410 we running. can someone say what pin i can get the speed signal from the jzs161 ECU?
  14. #44
    May 2010
    Moscow
    hititup, I fabricate signal converter for that. It takes sp2 signal and alters its frequency and amplitude to suit any analog cluster. ECU still sees proper signal. I've been making these adapters since my 1st conversion (in subscript)
  15. #45
    Aug 2015
    berbice
    Thanks.you is of great help. I will definitely get 1 of this adapter from you. I am just waiting on my mate to see what else his swap need.
  1. 1JZ-GTE [JZX110/JZS171] MAF issue
    By George in forum Tech and Conversions
    Last Post: 08-07-2016, 08:33 AM
