Results 1 to 3 of 3
Thread: best cam/valve spring setup for a tough 2/3T hybrid
    Nov 2009
    Default best cam/valve spring setup for a tough 2/3T hybrid
    Im about to buy double valve springs for my 2t head and im wondering what springs to use, BRDRacing say that you should contact them with your head and cam setup to get the right spring. The cam setup that i wanna go for is a nice lumpy street cam, i need a lumpy idle to go along with the gilmer belt noise , now I read on an old thread that this cam gives good power throughout the rev range and recommended by thetoyman75, i think its a 272 grind??
    Grind No...Advertised Duration....Duration.................Cam Lift
    ......................@ ×010²..............@×050²
    .................IN.........EX.............IN..... ........EX.........IN........EX
    401A.........293°......293°..........242°......... .242°......372².....372²
    the head will have 1mm oversize valves, porting, high comp pistons and bored out to either 88 or 89mm, any alot more work, it will have 45 or 48mm webers aswell.
    Can i just buy the ones from sleekaspares or do i need them made to suit my setup?
    Callum
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Default Re: best cam/valve spring setup for a tough 2/3T hybrid
    Ahhhh valve springs, worth your time having a look around...
    You need seat pressure and pressure over the nose from cam grinder first.
    Nov 2009
    ahh right i suppose brdracing would get all that info once they have a cam to work with , can anyone suggest a lumpy cam with good power throughout the rev range?
  1. 1G Valve spring specs?
    By cat007 in forum Tech and Conversions
    Last Post: 03-02-2011, 06:43 AM
  2. 2TG/3T GTE valve spring compressor?
    Last Post: 04-03-2008, 08:16 PM
  3. valve spring upgrade
    By dale30 in forum Tech and Conversions
    Last Post: 14-08-2006, 07:57 AM
  4. valve spring pressures
    By Celica RA45 in forum Tech and Conversions
    Last Post: 09-08-2006, 09:49 PM
  5. Valve spring recommendations
    By nick.parker in forum Tech and Conversions
    Last Post: 23-07-2006, 10:27 PM
