Results 1 to 2 of 2
Thread: RA40 Radiator Info
    Tasmania
    Default RA40 Radiator Info
    Ok I have a RA40 Celica that I'm in the process of putting a 7MGE into.
    I currently have a dummy 7M bolted in at the moment with water pump and harmonic balancer.
    Now what I need to know is what radiator will fit in behind where the original one sits. I don't care what it s out of and I'm doing this as a cheap but not nasty weekend warrior. Not interested in alloy aftermarket rads.
    Cheers Brett.
    Duct Tape Solves All Conversion King ivandude's Avatar
    Jan 2010
    Default Re: RA40 Radiator Info
    RA60, AE86 should be very similiar and work ok. Apparently Hyundai Excel is a choice too for RA40 rad replacements (only seen it mentioned by 2 RA40 owners but never personally seen it fitted).
    I know for 7Ms into MA61's that MA70 radiators been made to work, or if theres lot of S13s nearby you could use a S13 SR20DET that will line up all the ports/size as an MA61 radiator spec.
    "The standard RA40 radiator size is. (core size) 570mm wide by 485mm high. bolt holes are 210mm apart in height and 565mm width"
    1982 Soarer MZ11 1JZ-GE VVTi build
    1981-1985 Z10 Soarer Owners International Group
    Former rides ~~ RA65 '85 Celica ~ MA61 '84 Supra ~ JZA80 '98 Aerotop ~ AE101 '92 Levin Toyo4life
  1. RA40 & AE86 suspension info Needed
    By fergo308 in forum Tech and Conversions
    Last Post: 13-11-2011, 05:36 PM
  2. [INFO] 2JZGTE Radiator Hoses
    By infotechplus in forum Tech and Conversions
    Last Post: 03-07-2008, 09:34 AM
  3. RA40 radiator
    By strat in forum Tech and Conversions
    Last Post: 11-01-2007, 06:00 PM
